Antique Tractors - Old Iron Lugs, Cleats and Tracks Photos and information about antique steel wheeled farm tractors. This is where to find the heaviest of Old Iron.
Interesting tractor in Canada
Can anyone confirm the identity of this tractor, photographed at the Reynolds-Alberta Museum in...
this thread has 10 replies and has been viewed 1504 times
Old 01-11-2007, 03:52 PM
David Parfitt's Avatar
David Parfitt David Parfitt is offline
Default Interesting tractor in Canada
Can anyone confirm the identity of this tractor, photographed at the Reynolds-Alberta Museum in 1995? I think it's a Gilson, but not 100% sure. Would be interested to know what engine(s) Gilson used in their tractors. Any idea what on earth that smaller wheel below the steering wheel was for?? Perhaps someone has some Gilson literature they could scan?
Many thanks in advance
David
(Photo courtesy Henry Roskilly.)
www.steel-wheels.net
Old 01-11-2007, 04:43 PM
Default Re: Interesting tractor in Canada
David?
Looks like it could be a Gilson, made in Guelph, Ontario. Here are a couple of not so great shots taken at Austin, Manitoba Ag Museum. Their's has Waukesha, type R, 4and1/2 x 5and3/4. Dated c1918. It has Foote Bros tranny, 2 speeds, 60" rears, pinion inside Bull (ring) gear, disc type individual brakes. Rated 12-25.
Looks like they have changed the rad on the Austin one, and front wheels have flat spokes. I have some poor pix showing originals with round spokes like in your picture. I am not seeing the extra steering wheel you mention and recall nothing on Austin one?
There is also a Gilson in the Country Heritage Park collection in Milton, Ontario but it has a real oddball motor????
Hope this helps?
G.
Old 01-11-2007, 08:21 PM
Ross Clarke's Avatar
Ross Clarke Ross Clarke is offline
Images: 22
It sure looks like a Gilson to me.
You're right G, I have run the one in Milton & I think the motor is some old car engine, but the name escapes me. The clutch in it was dangerous, a spring clutch like on the light weight Rumely, pull to release the clutch and hope to he!! it doesn't slip out of your hand.
This one looks like it is the only truly original one of the 3.
I can faintly see the second wheel but have no idea what it is for as the other 2 do not have it.
Ross
Old 01-11-2007, 10:15 PM
JLBroadhead's Avatar
JLBroadhead JLBroadhead is offline
Grandads 39-57 minneapolis has that second wheel and it is a trans brake?
Old 01-11-2007, 10:39 PM
Ross
Ross!
Yes, I had the "pleasure"??? to run the one at Milton and you just reminded me why I preferred to run their Sawyer, or anything else! Also can't recall the breed of motor in it, but something just completely different!!??
I wonder if WDM has one in their collections? Likely eh? Chad Yelland, where are you?
G.
Old 01-12-2007, 02:35 AM
I've got a note on Gilson Mfg Co, Port Washington, WI, that supposedly produced the Gilson Guelph around 1918 in three sizes: 11-20, 12-25 and 15-30. Info apparently came from I&T's Vol I and/or Wendels Encyclopedia of American Farm Tractors (assuming I didn't get things confused); no tech info on my note. and Gilson doesn't show in a 24 piston catalog, but it's very weak on anything other than cars and trucks.
Old 01-12-2007, 03:13 AM
Bud: Can I ask what "I&T" is?
G.: Thanks for the pics of the Gilson at Austin. I have tried to lighten the photo above to show that second "steering" wheel a little better. You should be able to make it out below and just to the right of the main steering wheel.
Best wishes
David
Old 01-12-2007, 11:53 AM
Randy Kvill Randy Kvill is offline
It is a Gilson Style 18 15-30 tractor. Serial Number is 2004. It was manufactured in Guelph, Ontario. It is beleived to be a 1918. The engine is a Waukesha Model R four cylinder, 4.25 bore and 5.75. Engine number is 21423, date 3, 5, 1918. 30 hp at 1000 rpm. The Foote Brothers transmission is serial number 1262. The small wheel is the gear shifting handle.
It is still at the Reynolds-Alberta Museum.
Randy
Old 01-12-2007, 12:39 PM
David: The I & T volumes (Implement & Tractor?) are published (I assume) by the same company that puts out a lot of tractor/eqpmt manuals. They're along the same lines as the Wendel books except no (or very little) company background/history. Got them (Vol I 1916-25, Vol II 1926-56) out of the local library . If I'm recalling correctly they usually have a pic, either a photo or from an old ad/brochure, with a paragraph of tech info known. Naturally the larger mfr's have more models shown; it apparently had no engine info on Gilson per my notes (The independent US engine mfr's and what their engines were used in was my interest). Very nice books, well worth having, but haven't checked around to see if available or at what price.
Old 01-12-2007, 12:55 PM
Images: 17
Bud..........that I&T collection is actually a 3 volume set...........and WELL worth having.
The first volume has SOME history and so forth but TONS of early ads.....
I'm not sure if it's out of print either.................
Old 01-12-2007, 01:03 PM
On the "oddball " engine question, the "passenger car, motor trucks, motor buses, tractors, compressors and marine engines" lists in the 24 piston catalog (almost all cars and trucks) lists the following under "engines": Anstad (one car), Buda, Cont, Duesenberg, Falls, Gray, Herc, Hershell-Spillman, Hinckley, Lyc, Mid-West, Northway, Rutenbur, Van Blerck, Wauk, Weidley and Wisc. There's also (off the top of my head at the moment) Anderson, Buffalo, Chief, Climax, Beaver-Le Roi, Doman, Erd, Gile (believe they made some in-line with the horizontals?), Kermath, Light, Stearns, WSM...got a list here somewhere... (plus the relatively rare truck and tractor companies that made their own engines in the teens to the 30's and are now long gone).
Mogul 12-25 in Canada David Parfitt Antique Tractors - Old Iron Lugs, Cleats and Tracks 6 07-19-2010 09:26 PM
An interesting steam tractor PTSideshow Stationary Steam & Traction Engines 10 11-28-2007 01:39 PM
Ruston Proctor tractor in Canada David Parfitt Antique Tractors - Old Iron Lugs, Cleats and Tracks 8 12-14-2006 04:32 PM
OT Going to Canada Steve A Antique Gas Engine Discussion 10 09-19-2006 09:11 PM
customs/Canada Mike Royster Antique Engine Archives 5 05-01-2002 10:43 PM
