Partner 1616 chainsaw mix?
I have a Partner 1616 type 3 chainsaw and I am unable to find any info on it. I need to know the...
this thread has 2 replies and has been viewed 644 times
Old 02-09-2007, 06:33 AM
Leland Leland is offline
Default Partner 1616 chainsaw mix?
I have a Partner 1616 type 3 chainsaw and I am unable to find any info on it. I need to know the oil to fuel mixture ratio.
Old 02-10-2007, 02:28 AM
John G. Simpson John G. Simpson is offline
Default Re: Partner 1616 chainsaw mix?
Leland.
any small engine repair/ sales can give you a good mixture ratio. 2 cycle oil is about a 20:1 or 30:1 mix. synthetics are less
john
Old 02-17-2007, 12:27 PM
Exclamation Re: Partner 1616 chainsaw mix?
If engine was built in early 1960s or earlier, 16:1 (1/2 cup SAE 30 Non detergent oil/gallon gas should work - some engines even used heavier mix, for example, Fairmont railway engines use 12:1 and SAE 40 NON Detergent oil, Pacific Engineering fire pumpers also used 12:1, and even used 8:1 for break in! I also had an early 1950s vintage Jacobsen 2 cycle, that used an 8:1 mix (smoked like a bugger cold, but cleared up when hot)
Andrew Mackey
(BIG) Chainsaw Carl Chain Saw Collectors 2 11-01-2009 09:11 PM
Skilsaw 1616 Graeme Logan Garden Tractors / Mowers / Scooters 6 09-08-2008 05:47 AM
Skilsaw 1616 h.cole Garden Tractors / Mowers / Scooters 2 02-09-2008 12:53 AM
Partner 1616 chainsaw fuel mix ratio??? Leland Chain Saw Collectors 3 03-06-2007 06:04 PM
Partner Pioneer 400 Jason MacNeil Antique Engine Archives 0 10-19-2003 02:56 PM
