Signal Corp PE-108 E
this thread has 4 replies and has been viewed 2674 times
Old 02-09-2007, 06:41:36 AM
Leland Leland is offline
Default Signal Corp PE-108 E
I have heard that I need to use a jumper wire on the terminal plug to get it to start but I don't know which ones. Any I deas?
Old 02-09-2007, 09:08:35 AM
John Newman, Jr.'s Avatar
Default Re: Signal Corp PE-108 E
If you go to http://www.smokstak.com/forum/showth...ghlight=PE-108 there is a discussion on these generators. To answer your question about the multi-pin terminal plug, I have copied my information from that post below:
If you take off the flat tin panel on the end of the control box above the gen, I found inside a lithographed tag with the wiring schematic on it.
It identifies the round plug connections when looking at the back of the plug (inside the control box). I have identified them below by location when looking at the front (outside the box) as follows:
Looking at the plug (from the outside) there are 6 pins arranged in a circle and a 7th one in the center. Pins at 11 O'Clock and 1 O'Clock are connected to the 110 VAC recepticles. 3 O'Clock pin is starter relay. 5 O'Clock pin is 12V Battery (+). 7 O'Clock pin is 12V Battery (-). 9 O'Clock pin is for the choke solenoid. Center pin appears to be ignition kill, but I am not 100% positive on that - schematic looks like these may have been available with battery ignition as an option....
Hook up a 12 V battery to the posts shown on the picture of mine above, the + terminal is the one closest to the engine & meter. By putting a wire in the pin hole at 3 O'Clock and grounding it to the frame, it completes the circuit for the starter solenoid and should spin the engine over
Hope this helps,
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 02-09-2007, 07:35:32 PM
Mike Schweikert's Avatar
Mike Schweikert Mike Schweikert is offline
Images: 26
I have a PE-108B from 1943
This picture should help.
Use a 12-14 guage piece of romex. You simply push it in, and when it starts take it out. A very cheap key. I hang it on the battery cable. I use a small garden tractor battery mounted on that side of the generator.
I use mine mostly for lights, (600 watt) it was used for mobile command radio set SCR-543, either in a truck or base. The plug went to the Radio set, which had a remote control to start/choke and stop it by pressing the right buttons.
Mike
Mike Schweikert
Jamison PA
See my videos at: http://www.youtube.com/user/standardtwin1
Old 02-11-2007, 05:25:06 AM
Thanks Mike, I became the owner of this machine when my grandfather died. I am wondering what it might be worth? Is it an antique? Leland
Old 02-11-2007, 10:06:38 AM
Images: 26
Well it is worth only what someone would give for it.
Realistically it is only good for 600 watts as a limitation. But it is a military item, and built like a tank, and will start off of and charge a 12 volt battery at the same time.
I paid $85 for mine two years ago in good running condition, no knocks or smoke if that is any guide.
I used it to power lights and industrial fan to dry things out during a flood condition last year, and I ran several tanks of gas through it. It was running at full load and then some, and never let me down. If you are a real survivalist, one could run a 12 volt inverter off of the battery and then charge that when it was depleted. In that case it was worth far more than the money I had paid for it
Mike Schweikert
Jamison PA
Pe-95-f Signal Corp Generator Kirk Onan Generators 3 01-06-2016 03:24:19 PM
Signal Corp Power Unti PE-75-u VW Vanagon Small Air Cooled Gasoline Engines 7 07-19-2015 05:57:04 PM
US Motors Army Signal Corp Jerry Park Generators & Motors General Discussion 9 12-21-2006 10:58:48 AM
signal corp PE 75 AA smiley Generators & Motors General Discussion 2 12-06-2004 06:24:12 PM
