Welding Broken Exhaust ManifoldGreetings.............. I have an exhaust manifold off a 1938 DeSoto 228 flathead six long block. ...this thread has 7 replies and has been viewed 2317 times
Greetings.............. I have an exhaust manifold off a 1938 DeSoto 228 flathead six long block. (in a 38 Dodge Humpback Panel Truck) It has a broken piece off one of the four corners where the exhaust pipe attaches. I couldn't find the piece any where in the collection of parts when I bought it. Where and what should I look for when chosing a welder to do this restoration? Thanks
Francis. are you doing a restoration or making a runner out of it?
it can be built up with ni rod (arc weld) or it brazed. don't mig weld it. i normally braze manifolds, as they are often too thin to arc weld, if only the flange is missing arc welding will work great. have you tried some of the chrysler obsolete sites. e-bay has some sites also hope this helps. john |
In all honesty, start by finding a replacement manifold, because a beginner doesn't stand a snowball's chance in hell of welding a cast exhaust manifold successfully.
Sounds like you need "PROFESSIONAL" advice or a "PROFESSIONAL." Most Welding shops sould have someone that can weld it for you or give you "PROFESSIONAL" advice. When we had a welding shop we charged about 60.00 per hour. DAn
I agree with John & Franz here, cast is funny to weld, & takes some skill to repair, heating both metals being welded & cool them together,, slow evenly is just part of the key,,,if you have not welded before this is not the piece of metal to try on....I would look for a manifold first also.like suggested good luck, Francis Dan if you guys had a welding shop. Why did you close it up.. NO work orworkers that did not know how to weld,,,or just did not show up for work, just wonder , because "Good" welding shops are hard to come by |
Francis..................on old, likely pretty well burned, iron like that about the only way is to gas weld it with cast iron. I seriously doubt any dissimilar metal will stick.
If you can't find anyone local.......... ............
I just didn't show up for work. Came into work on day and decided to get on the phone and purchase a plane ticket to Mexico for a vacation.When I came back my co-owners had decided that they didn't want to do it anymore. We just weren't that good at welding either. You know what I mean. Just an American dream that wasn't mean't to be.Chronic back pain I suffered after an accident had something to do with it to. But ya your right there guy on all that you said you know. No work, not GOOD at welding, not showing up....etc.etc.. Well you know the story. And somtimes your country calls you to more important issues. DAn
I have an idea that may be of help, I recently did this on an exhaust manifold for an old[no replacement part available]4 cylinder diesel. The area where the manifold bolted to the pipe was so deteriorated and the threaded holes so thin that you could read thru it, and nothing could be attached to it. What I wound up doing was to cut off the outlet side to where it was a little thicker, and keep a good measurment of the length and clock positions of the threaded holes, and I duplicated that onto a piece of stainless steel, and bored that so it fit over the end of the manifold that had been cut, and clean, clean, clean the manifold, and generously flux both the old and new pieces and then braze them together. The customer was very happy, and commented that the repair would probably outlast the origional part, and the stock exhaust pipe could still be used.
Mike |
| Cracked Exhaust Manifold | hwh888 | Generators & Motors General Discussion | 1 | 09-10-2007 09:57 PM |
| Exhaust manifold problems | John W.L. | Onan Generators | 4 | 08-04-2007 10:51 PM |
| Wisconsin TH vs. TJD exhaust manifold | Shootist357 | Small Air Cooled Gasoline Engines | 1 | 01-08-2006 02:51 PM |
| Help again! Need exhaust manifold gasket | dwelshans | Generators & Motors General Discussion | 5 | 06-19-2005 10:07 AM |
| wisconsin VF4 exhaust manifold | chuck cleveland | Generators & Motors General Discussion | 0 | 09-21-2003 09:09 PM |
