Stihl 041 AV from 1963
does anyone know the correct fuel mix for this saw. old flat top airfilter. not the farm boss.
this thread has 13 replies and has been viewed 3029 times
Old 03-06-2007, 03:31 PM
youngmaytagstud youngmaytagstud is offline
Default Stihl 041 AV from 1963
Old 03-06-2007, 06:01 PM
Chisel Tooth Chisel Tooth is offline
Default Re: 041 av, 1963 stihl
50 to 1 is the recommended ratio, for all Stihl hand held products.
See Ya
Mike
Old 03-06-2007, 08:05 PM
Back in 1963 im sure that saw ran a 16:1 ratio. I dont care how good todays oils are I wouldnt run it leaner than 40:1 or 32:1. The carburation is set up for a heavier mix and wont make the engine run lean like it would do to a new 2 cycle.
Old 03-06-2007, 09:04 PM
i agree, i would never run leaner than 32:1 in anything, i dont care what stihl says, they just want you to buy another saw. i work on saws for a living, and ive had to part out too many saws because of scoring. i was just wondering if i should run 16:1. but i think 32:1 with the new oil would be ok and not hurt anything
oil is cheaper than a cyl kit.
Old 03-06-2007, 10:10 PM
Well todays oils are much better. I think a 32:1 ratio is perfect for the real old 2 cycles, 40:1 for the new stuff. Obviously if you get a lot of smoke even under load and the muffler is dripping with oil you can cut it back to 40:1. If the muffler is just wet and the smoke isnt bad at 32:1 the I would stay with that. 16:1 is a VERY heavy mix and should be avoided as that was a ratio for oils no longer having those additives and consistancies (thank God).
For what its worth Amsoil has a 100:1 synthetic mix but thats really asking for trouble on old engines with loose clearances.
Old 03-07-2007, 03:08 PM
I run my 650 Mac at 50:1 and have done so for over 15 yrs. I've been working on small engines scence the age of 12 and I'm 47 now. Trust it or not but with the modern oils 50:1 works for just about everything. But according to the manufacturer you are to run Castrol SAE 40 mixed at 20:1 with regular gas. I have alot of customers that have older saws and run the 50:1 mix for years and have had no problems.
See Ya
Mike
Old 03-07-2007, 08:17 PM
Ive been working on small engines the last 30 years and im 42 now, im also Bronze certifed in Stihl going for silver this year. I really dont think running that ancient saw on 32:1 or 40:1 will hurt,esp with todays quality oils like Stihl and Shindaiwa,etc sell. Oils in dept or parts stores should be avoided. With a 50:1 ratio it doesnt take much of a lean carb adjustment to seize or ruin a 2 cycle if the carb is adjusted wrong or the metering diaphragm is hardened and starves the engine slightly if the saw is being worked hard. In his case of a saw of that vintage they have the torque at low rpms and it puts more stress on the bearings where as the newer saws rev much higher to achieve that torque and have less internal stress as they are happy at those revs and stall when bogged to the rpms of those ancient ones.
Old 03-08-2007, 02:08 PM
_I agree it is the fact that the older saws don't run the high RPMs, as the new saws. You want to be sure that the oil you run is a oil classified API-TC,(American Petroleum Institute) JASO-FC,(Japanese Automobile Standards Organization),or ISO-LEG-D,(International Organization for Standardization). ISO specs add to the JASO for the level of detergency protection against rings sticking and varnish deposits.
API-TC is not as ridged as the JASO and ISO requirements. You will learn this at the school in Marble Hill.
_ I'm headed to Virgina Beach to get my gold, sometime this year. I also hold certs. Briggs, TEC, Kohler, MTD, Redmax, Poulan, Shindawa, Echo, Dixie Chopper, Gravely, Ariens same as Gravely, Toro, Generac, and a few others I let expire, I don't work on them anymore, Homelite was one.
_ Good luck at the school, Kick Van Greer in the knee for me. Just kidding. Get them to let you stay in the hotel in town if you can they have a good breakfast bar. Silver takes two days, so don't fall asleep.
See Ya
MIke
Old 03-09-2007, 12:22 AM
Mike I wont be going to Virginia Beach until next year for the gold. Just the local CT Stihl distribution center for silver testing for 2 days. I agree they feed you well, but not as good as Exmark does.
Old 12-17-2008, 07:19 AM
Bruce The Mac Hopf Bruce The Mac Hopf is offline
http://www.acresinternet.com/cscc.ns...1?OpenDocument
I just looked up your Chain Saw here at this website, and it calls for 40:1. Some Stihl Chain Saws call for 50:1 Not all like someone previously said. I have McCulloch Chain Saws here that were built in 1965, and 40:1 was the Standard Mixture for them then. I also run Stihl Chain Saws as well, and I use Stihl Premium Oil at 40:1 for all my Chain Saws. Even the ones that call for 50:1. 40:1 has a little more Oil in the Mix, and it wont hurt anything. Bruce.
Old 12-17-2008, 07:29 AM
See Ya
Mike
I think you had better do some Research Mike, and you will find that No All Stihl hand held Products call for 50:1. Very Very Few Stihl Products call for 50:1, but mostly call for 40:1. Bruce.
Old 12-17-2008, 11:59 PM
bull bull is offline
Default Re: Stihl 041 AV from 1963
STIHL recommends a 50:1 mix when using STIHL branded two cycle mix oil (2.6 oz. of STIHL branded oil for 1 gallon of gasoline) on all of our gasoline powered equipment.
This is off the stihl web site. At the time stihl switched to te 50:1 mix. They did some testing and had data showing that the head tempiture was reduced using the higher mix.
Marty
Old 12-27-2008, 07:10 PM
John Marrais John Marrais is offline
It's certainly not going to be a 1963. We were selling brand new 040 saws mid 60s. 041 came after the 040. I first went to work as a saw and tractor mechanic mid-60s for a Deere, Homelite, and "oddball" dealer. I say "oddball" because we sold Solo and Stihl before they had any real presence in the USA.
As far as the mix, it based on the oil you're using, not the saw. When Stihl was recommending plain-grade 40 weight motor oil - the mix was 20 to 1. With marine-rated two-stroke-cycle oil - it was 25 to 1. With Sithl-brand two-stoke-cycle oil it was 40 to 1. As far as saws today - I don't pay attention to the new specs since they are partly based on emissions laws - not what's best for the saw.
Old 12-27-2008, 07:28 PM
http://www.stihl.ca/company_history_prod_1960.asp
site.......
Stihl chainsaw 030 AV Sky Chain Saw Collectors 7 12-22-2008 12:31 AM
Stihl Chain Saw Mix Ralph Leonard Chain Saw Collectors 7 12-17-2008 09:45 PM
1963 Mercedes 190 Diesel Chris J Antique Autos and Trucks 11 12-10-2007 07:43 PM
PA Compressor Station photos from 1963 Robert Pence Antique Gas Engine Discussion 11 11-29-2006 10:10 PM
The 1963 djb lives again....for about a minute! mav7771 Onan Generators 11 06-29-2005 12:27 AM
