Running mini hit and miss motorDoes anyone here know what is the going rate for a mini hit and miss motor that runs? I have always...this thread has 16 replies and has been viewed 3158 times
Does anyone here know what is the going rate for a mini hit and miss motor that runs? I have always wanted one but i mainly see castings for them and i dont know how to make them so i would rather buy one already built and running.
Chris from Washington (the state)
Chris, send me a private message and I will give you the name of a guy that may still be selling completely assembled, running engines.
Frank |
Barstock engines are often found fairly reasonable (I sell them see here, or check Harry's bizcard page!) . OTOH engines built from castings generally are quite spendy
Theres a Irwin model listed in harrys engine ads right now for $600.00
thats a real good deal on a entry level model. JAMES gehringer |
I have sent some emails off about model engines in the USA but have not
had an answer, maybe people don't like sending too us down under in Australia, so if anyone has a contact I would like to buy one as well! Regards Andrew
The problem with shipping out of the USA is risk and cost. Most buyers grouse about $150.00 shipping within the USA and then about $75.00- $100.00 for proper crating. A model engine in the 8-10 inch. flywheel range can weigh 75 lbs. plus-plus the weight of the crating:. There is alot of potental carelessness between here and Downunder so one must add the cost of insurance too. Insurance will cover the value of the model but not necessarly the crating and shipping that could turn into a loss for the buyer. Which could end up being a blackmark on the builders reputation.
The only way I would ship of of country is a double wooden crate, fully insured. So we could be talking $400-$500 just to get the model to the customer. Add that to the price of a well built model and we could be talking well over 3 grand for the average model. Something like a Mery or Callahan a whole lot more! Deep pockets required!! Buddy Harley harloc-model-engines.com |
Buddy, Thanks for the reply, I am glad too hear that you would want to see that the model would get to the buyer in one piece, so I also would want to buy a model off someone who would crate and frieght it well so we would get what we paid for!!! Yes it is alot of money but you can't take it with you, and you are dead along time, and I would like a model hit miss engine to run while I can. Hope I can find one soon regards Andrew
There is an easier way to ship a model then to double crate it. Build a box that would allow around 3 inches all the way around the model. Put the model in a very thick plastic bag with one of those drier packs. Then, spray the expanding foam in the bottom of the crate a few inches thick, it will expand so don't let it set up all the way before placing the model (wrapped in the plasic bag) in the crate. Then all you have to do is to fill the rest of the crate with the expanding foam, let set up and cut off the excess, fit the top and ship. The buyer will have a bit of a mess getting the model out, but it will be clean and free from damage. I've never had a problem with this method and it does reduce the cost of packing and shipping.
Tim Christoff Basehor, Kansas. |
Tim
I've been thinking about that method. However, I was thinking that maybe the spray foam could also be contained in plastic bags. Or at least the upper fill. As you said, spray a good amount in the bottom, set the bagged model down in it and allow the foam to set-up, then cover the whole area left with plastic and finish filling the crate. This method should make it easier for the buyer to remove the model without risking damage. I haven't tried this yet, but am thinking about it. Buddy Harley |
Buddy, thanks again, the foam in a can system works for gauges and other glass parts, I would like to see what you offer in models, and hopfully other will look at these ideas and think about us down under, regards Andrew.
Andrew,
You could contact Reggie Ingold and see what he has for sale or might build for you. He's in Oz, so shipping might be a bit easier. He has a web site on the http://www.oldengine.org server. <<Jim>> |
Thanks for the tip, tried Reg and he put me onto some one selling off his models but I am still looking for a TomThumb or flame licker would be nice
Regards Andrew. |
Hey Chris J, not sure if you have a lathe but you might want to keep an eye out for a set of plans or something to make a simple bar stock engine first then move on to a set of castings. A lot of these models can get expensive to buy finished & you'll get more out of making one yourself. I have some finished hit & miss engines for sale ($600) but they hit-miss by cutting out the ignition rather than the exhaust valve.
the websites' at http://newrmc.20megsfree.com On shipping with that expand-a-foam, I used it once to ship a big brass train bell down South & had to stay under the mail weight so I used the foam to keep the weight down. I wrapped the bell in like 3 trash bags & used the foam around it in a light box. It ended up being right under mailing weight & the guy it was sent to said it made it fine....he had to chisel it out though. -nick |
sounds dumb but i found insilashon to work for packing not border insilashon with tin foil cover but fluffy window insilashon packed tight a thought
I have 2 RedWing 1/4 scale model hit & miss engines just about finished .Pictures of models are in my profile.if you are interested send me a private message
Mike |
I have two Redwing Thorobred engines. Will sell one. PM me for details.
| Got the canoe motor running | Mark Mohney | Antique Marine Engines | 6 | 02-17-2008 01:18 PM |
| Running Hit Miss Engine Builders | d23j | Scale Model Engineering | 4 | 05-03-2007 04:06 PM |
| Running 50Hz 3-phase 10hp motor at 60Hz? | R Huck | Generators & Motors General Discussion | 5 | 10-04-2006 10:29 PM |
| Trade hit & miss for bi polar motor/dynamo | Larry Healey | Generators & Motors General Discussion | 0 | 10-14-2003 04:46 PM |
| The Mogul Runs! Hit & Miss,Miss,Miss, Miss,Miss | Dan Bogart | Antique Engine Archives | 7 | 06-24-2003 01:10 AM |
