29 Plymouth Distributor DriveHELP!!!!! I am in need of a good Distriutor drive for a 29 Plymouth Seden... Any ideas where...this thread has 4 replies and has been viewed 737 times
HELP!!!!!
I am in need of a good Distriutor drive for a 29 Plymouth Seden... Any ideas where to find one or if anyone has one they are willing to get rid of.....
If you haven't checked them already, two Mopar sites that come to mind are P15-D24.com and allpar.comm/net/org?, and there are no doubt more on Google. Rebuilders may have what you need (not clear if you need the dist shaft or the drive gear/slot) (probably turn some up Googling Distributor Rebulders etc) if the archives on the Mopar sites don't recommend any. Good luck.
I'd also try the Plymouth Owners Club. They do have a website, but you'd probably do better to contact the club's technical advisor for the '29 model. You should be able to look up his name & email address off the club website. If not, PM me & I'll send it to you.
Thanks Guys that does help.....
Unfortunatly the car is at a good friends place and I don't have tha part in front of me but what I am told is the drive that drive the distrb is what I am looking for..... Thanks again for all the help....
I have a 29 Ply and also needed a distributor drive. If you will contact Tom Hannaford at Antique Auto Parts Cellar 718-335-1579 they make their version of this drive and housing. They have a whole new bronze cast base and gears for #395.00 He is well versed in this drive and can supply any needed info. Usually the original 90 deg. base is not usable because it was made of pot metal. THEIR gears and shaft only fit THEIR base. (job security I guess) Hope this helps. Happy Motoring!!!! - Rich
| Tractors equipped with Atwater Kent distributor and coil | Randy Reysen | Antique Tractors - Old Iron Lugs, Cleats and Tracks | 2 | 04-01-2009 08:43 PM |
| Wanted Chrysler Crown Distributor Cap | Bryan Hughes | Antique Marine Engines | 12 | 03-14-2008 02:04 PM |
| 1949 Case VAC/ Autolite distributor | smcowboy1974 | Magnetos, Ignition Coils and Spark Plugs | 0 | 11-09-2006 05:16 PM |
| Plymouth Tractor? | Greg Downard | Antique Tractor Talk | 8 | 08-18-2005 06:27 PM |
| Distributor | Marty | Antique Engine Archives | 0 | 09-09-2003 09:53 PM |
