1/4 Scale Bentley BR2 Rotary Engine
http://www.rjdunn.co.uk/tony/aero/thumb0001.htm This is a well done job. And it runs. Jim
this thread has 6 replies and has been viewed 1898 times
Old 03-26-2007, 11:12 AM
Default 1/4 Scale Bentley BR2 Rotary Engine
Jim
Old 03-26-2007, 02:16 PM
Forrest A's Avatar
Wink Re: 1/4 Scale Bentley BR2 Rotary Engine
Not a dig, I was just expecting to see a rotary engine from the title of the thread.
For those unfamiliar with this type of engine it is actually a radial type. A rotary engine is quite different. See the link below.
http://auto.howstuffworks.com/rotary-engine.htm
Forrest A
Old 03-26-2007, 02:27 PM
Alan New's Avatar
Alan New Alan New is online now
Default Re: 1/4 Scale Bentley BR2 Rotary Engine
Actually, the Bentley BR2 IS a rotary. It was and improved version of the Clerget rotary. Many aircraft, as well as some automobile engines built before and during the World War 1 era were rotaries or rotating cylinder engines, as opposed to fixed cylinder "radial" engines. They felt that the air cooled cylinders had to rotate around the crankshaft for effective cooling. the early radials were liquid cooled. These came many years before Wankel developed his "rotary".
Old 03-26-2007, 11:02 PM
W.B.Lewis W.B.Lewis is offline
Smile Re: 1/4 Scale Bentley BR2 Rotary Engine
A member of New England Model Engineering Society in Mass. has one which he shows regularly at shows in the Northeast. Nicely done model.
Old 03-26-2007, 11:10 PM
maryjane30 maryjane30 is offline
hi all
if you want to see a full size pre ww1 rotary engine running, there is on on youtube I saw..
http://www.youtube.com/watch?v=R_JMGO5NzuI
should find it. the engine is definatley a rotary, the Bentley was the last form as fitted to the sopwith snipe right at the end of the war. the torque of the spinning engine was what made the sopwith famous for its "immellman turn". the bently however was as big as they got,(200hp) they became too hard to fly straight, basically.. the gnome as in the video link was 50hp, and the first aero engine in 1909 to fly more than 1 hour, loop the loop, and fly upside down, as well as numerous other achievements!
the crank was bolted to the firewall, and the prop to the engine crankcase.
nice work though.
M-J
Old 03-28-2007, 03:16 PM
John Davidson John Davidson is offline
FYI, the true rotary engine where the crankshaft is stationary and the cylinders revolve was developed in 1898 by Fay Oliver Farwell. It was a 3 cylinder engine. In 1903, working at the Adams Co. of Dubuque, Iowa, the ADAMS-FARWELL car was produced with the 3 cylinder rotary engine. In 1906, a 5 cylinder model was produced. Production lasted till 1913. There exist one 1906 5 cylinder car. The horizontal cylinders were mounted directly over the rear axle. No flywheel need or cooling. It was in the Harrah collection. I saw it running in 1968. An amazing thing to see and I will never forget it.
Old 04-01-2007, 03:03 PM
Exclamation Re: 1/4 Scale Bentley BR2 Rotary Engine
The Gnome engines actually ran too cool! They used to foul plugs like mad. The cowl was designed to cut down airflow, so the engine would actually run hotter!
Rotary Valve Diesel Engine Jud Antique Engine Photos 4 09-23-2007 04:09 PM
1/2 scale 1/3 scale steam engine Dale Stationary Steam & Traction Engines 5 10-16-2006 11:06 AM
1/2 scale Kitten Steam engine/1/4 scale case KG1584 Stationary Steam & Traction Engines 9 07-21-2006 01:21 AM
rotary engine 21avery Antique Gas Engine Discussion 0 05-21-2005 04:59 PM
Rotary Engine (offtopic) Mike Inglis Antique Engine Archives 1 11-17-2003 10:43 PM
