Flywheel Sears Craftsman 3600 generatorI need a flywheel for a Sears Craftsman portable 3600 watt generator. The generator model is...this thread has 2 replies and has been viewed 1688 times
I need a flywheel for a Sears Craftsman portable 3600 watt generator. The generator model is #580-328-340. The sears part number for the flywheel is #191-65189. The numbers stamped on the flywheel are #4192, ff5944, 861008, 3M82396S. Sears no longer carries these parts. Does anyone know where I could find one? Ron
Can you post a picture or two? Being 3600 watt the engine is most likily a Tecumseh H-70 or HM-70 and I may have a flywheel that would work. I have several older Tecumseh flywheels, most from blown-up vertical riding lawn mower engines that have a starter ring. If you can use a flywheel with a starter ring it is very easy to add a starter for electric start. I did this for my Fathers HM100 (10 HP ) Tecumseh on his 5000 watt generator. If you can not use the starter ring and the flywheel I have will work we can always remove the starter ring.
Kent |
Ron-
This may not be much help, but the "580" in the Sears model number is their source code for Generac portable generator group, now owned by Briggs & Stratton. I checked parts & model at the Sears web site for 580.328340. The engine is a Kawasaki Model FG300-DSX, Sears part number 65189. I wonder if they have an entire engine in stock? Fred |
| Craftsman Generator Parts | Larey | Generac Generators (SEARS, etc.) | 6 | 11-05-2007 11:25 PM |
| Craftsman 143.556072 generator | ncflatfender | Generators & Motors General Discussion | 2 | 10-22-2007 09:36 AM |
| Sears Generator with 2 Cyl Wisconsin | Jud | Generac Generators (SEARS, etc.) | 11 | 03-08-2007 09:50 AM |
| Rectifier board for Craftsman generator | Joe Stewart | Generac Generators (SEARS, etc.) | 22 | 10-12-2006 02:14 AM |
| Sears generator | Royce Gaylord | Generac Generators (SEARS, etc.) | 5 | 07-26-2003 02:31 AM |
