Jerry Kieffer's 1:8 scale D John Deere
I posted a video I shot of Jerry's tractor driving on You Tube. ...
this thread has 8 replies and has been viewed 1337 times
Old 03-30-2007, 02:16 PM
Forrest A's Avatar
Default Jerry Kieffer's 1:8 scale D John Deere
http://www.youtube.com/profile?user=mascobe
Forrest A
Old 03-30-2007, 08:24 PM
gbritnell gbritnell is offline
Default Re: Jerry Kieffer's 1:8 scale D John Deere
I've seen Jerry's tractor on several occasions. Extremely impressive, all of his work is.
gbritnell
Old 03-31-2007, 03:59 AM
maryjane30 maryjane30 is offline
thanks for the clip, first time i've seen this running.. now a question.. is it timed right? maybe its just running fast, but sounds a bit regular for a johnny popper? what does everyone think?
M-J
Old 03-31-2007, 08:13 PM
Hi MJ, having built some very small engines I can tell you that they have to run faster because they don't have enough flywheel weight to keep them going. You can increase the size of the flywheel but then you can't build an engine to scale. That's one of the physical problems in scaling down full size machinery. You can build everything in miniature but things like carburetion, ignition and physical forces can't be scaled and still work properly.
gbritnell
Old 04-01-2007, 12:20 AM
Benjamin Roth's Avatar
Benjamin Roth Benjamin Roth is offline
Yes, it runs fast. I remember Jerry talking about lowering the compression ratio so he could still have a scale flywheel and not some big ugly thing hanging there. It runs a little slower now that it is getting broke in.
Benjamin
Old 04-01-2007, 08:33 PM
Kelly Tytlandsvik Kelly Tytlandsvik is offline
Images: 260
I e-mailed Jerry a few months ago to get an update on the Harley he is building. He told me the Harley will be on the back burner for awhile as he plans to cover up that beautiful machining job with some green paint. He said he does have it slowed down more now that he has tweaked a few things!
It is a Museum quality piece! He had it here in Estevan at the show twice and was a real show stopper! It is perfect........right down to the proper number and size of holes in the aircleaner stack!
Kelly T
Old 05-11-2007, 02:57 PM
Forrest A's Avatar
A note about the RPM and the comp ratio, the RPM has slowed the more it has been run. It will however never run at the rated 900 rpm reliably due to the laws of physics. As for the compression the real tractor has a 4:1 compression ratio and Jerry, initially had too much built into tne tractor. It does fire correctly and would sound just like the full sized tractor if it did run at the same speed.
I know a fare amount about the model D and have been a reference for Jerry, he has a real 1936 D and I have one as well. The tractor was designed to run on kerosene/distillate and so the compression ration needed to stay low or pre-detonation would occur. A water injector was used to dampen the mixture enough to prevent pre-detonation as well.
I had my D on a dyno last fall and it was putting out 47 hp at 900 RPM which is 5 hp higher than rated. I always wondered what it would do with compression boost. There is ton of space left in the cylinder when the piston is at TDC, as much volume as some small car engines displace.
Forrest A
Old 05-12-2007, 12:16 PM
ronm ronm is online now
Hey Forrest, somebody builds "donuts" for the tractor pullers, it's a ring that fits in the combustion chamber above the piston, has a flange that lets the head hold it in place. Raises the compression a lot, I don't know exactly how much...I suppose you could specify what you want. I think they pretty much make an electric starter necessary...There's a D around here that has the spark plugs in the head, which would seem to imply "loooong" pistons... the guy claims "lots of mods" but won't really tell anybody what's in there...It didn't seem to me it pulled that much better than a stock D...
Ron in CO...
Old 06-08-2007, 02:38 PM
Forrest A's Avatar
Ron,
There is more to making horse power than just boosting compression. My guess is he hasn't done much to help the air enter the engine quicker.
I have seen the doughnuts and also the 0.125" over AL high compression pistons (which is a HUGE jump in displacement), some were just on eBay.
Forrest A
John Deere 6HP waterlooboy76 Antique Gas Engine Discussion 2 02-29-2008 02:33 PM
Jerry Kieffers 1:8 scale D, Painted Forrest A Scale Model Engineering 12 10-04-2007 03:12 PM
1/5th scale model john deere tractors Jordan Scale Model Engineering 8 03-13-2007 11:46 AM
1/2 scale John Deere RWG Antique Engine Archives 0 01-09-2000 07:07 PM
