Stabilizing Jacks...What to use?
On my trailer I want to add stabilizing jacks. What do you use and how are they mounted? ...
this thread has 4 replies and has been viewed 1329 times
Old 04-01-2007, 02:55 AM
Too_Many_Tools Too_Many_Tools is offline
Default Stabilizing Jacks...What to use?
Pictures would be great.
TMT
Old 04-01-2007, 08:13 AM
MoRo's Avatar
MoRo MoRo is offline
Default Re: Stabilizing Jacks...What to use?
What does this trailer do/haul? How large is it? How much weight are you wanting to stabilize??
Old 04-01-2007, 11:12 AM
Randy Hart's Avatar
Randy Hart Randy Hart is offline
Images: 2
The crank up jacks found on farm equipment attach over a welded pipe with position holes for transport or down.. The other style I have seen use square shoulder U bolts and clamp around the box or C- channel frame.
Another type has a square ram and the pivot mount can be bolted to the frame or U bolted. TSC, RKO, Harbor Freight or other farm related supply stores carry them for less $ than the farm equipment dealors. hope this helps.. Randy Hart Ohio
Old 04-01-2007, 12:46 PM
Exclamation Re: Stabilizing Jacks...What to use?
I went to a junk yard, and bought several screw type jacks from a Nissan car. They attach to the channel iron frame on the trailer, and are cranked up by means of a bellcrank. 1 Crank can operate all 4 jacks. Total cost - $10
Old 04-02-2007, 12:19 PM
bocephus_k6 bocephus_k6 is offline
Well I dont have any pictures of what we use for stabilizing our trailers, but simply put its 2 pieces of heavy wall square tubing, I believe the outside one is 2 1/2 inches and the inside slides in and out freely. These are welded front and back of the trailer on each corner on about a 22 degree angle or so , the inside tube has holes drilled in it about every inch or so for adjustment and we simply lift the trailer up with a screw jack like used on the tongue of trailers, set the stands at a height which leaves the tires almost off the ground,insert the pins in the stands, place some 2 inch thick oak plank pieces about a foot square under the legs and let it down on the stands. trailer has never moved on us yet.
Hope that helps some
Brian
Simplex RR jacks Corey Robinson Antique Gas Engine Discussion 5 05-19-2006 05:45 PM
Pump Jacks BobRR Farm + Industrial Antiques and Collectibles 16 06-07-2005 12:04 AM
Small old pump jacks rockytopp Farm + Industrial Antiques and Collectibles 6 03-13-2005 09:14 PM
Pump Jacks Tom Antique Engine Archives 2 05-30-2004 10:46 PM
Pump Jacks Dan Lawrence Antique Engine Archives 1 02-24-2003 09:17 PM
