Continental Red sealBeen looking for info on these engines..Seems they were used in alot of equipment..6...this thread has 13 replies and has been viewed 4603 times
Been looking for info on these engines..Seems they were used in alot of equipment..6 cyl.continental Red Seal engine...in a General Toro f226 is on the engine tag..trying to find a year on this Toro.. grounds keeper..or any other info you might have...Looks like Arnold Palmers old golf course tractor in the penzoil Commercial..we do have it home now...Byron..
Like this one only older... http://www.mytractorforum.com/attach...chmentid=11763
Not quite this old but it was cold as h*** when we saved it... http://users.crocker.com/~jricci/tgtregistry.html
Yes, the F226 was a popular little engine, apparently used mostly in farm stuff; a number of posts have referred to it in various pieces of farm eqpmt..
My 50 Motor Trk/Trctr Man shows it as an L-hd 6, 35/16 x 43/8, comp 6.00, Tqe 168@1000, BHP 72@3000 in the "automotive" (truck) version, but doesn't give any comp, tqe or BHP for the F226 version in the M-H 44-6 1947-48, the 101Sr 1942-45, or the 102G Sr 1942-45. Your local library should have copies of the Motor manual for the specs (sorry; no scanner) Remember Continental used, at least for awhile, three different numbers for the same (basically) engine depending on use:for this engine it seems to be F6226 for the "automotive" (truck) version, F226 for "industrial" (which includes farm tractors and eqpmt), and (if the then system holds true), probably PF226 for the "power unit" version. But can't help at all on the date of your rig. Good luck. |
Hey Bud:: thanks for all the info:Byron
The Continental Red Seal F226 was used by Kaiser in their cars...when Kaiser bought Willys-Overland that engine ended up in a lot of Jeep trucks and Utility Wagons...it was marketed as the "Willys SuperHurricane" and replaced the smaller "Lightning" 6 that was used prior to 1954. I've had a fair amount of experience with them and consider them to be just as good as the Chrysler flathead sixes...particularly in 4wd applications. (where low rpm and smooth, high torque rule the trail---give me a flathead six in that rock crawling jeep anyday...and I'll embarrass a lot of 350 chevy owners!)
rh |
My dad had a 1963 Checker that he bought new (not a taxi cab) that had a Continental 226 cu.in. engine in it. Not a real powerhouse, but it ran forever.
The F-226 was a very popular engine. It was replaced by the F-227. different block head and crank. Now what you need to watch the automotive engines such as in a Jeep run a timing chain. The industrial engines run timing gears. So cams are different because of opposite rotation. I think a man in Toledo can help you out on dating those engines. He also has a ton of parts. John
Thanks for the info guys..Was wondering if these tag # only tag found so far ,,Someone might have a book to date this engine..Tag sez...Model F226,,,Spec#1578....Engine#122614.....Bidding on a book on E-Bay..Put don't know if we can still date it ..Thanks again for all the help..Maybe there was not many made or on a order basis..I don't remember ever playing golf..
Byron
Seems we got a date on the engine..63 so we figure this jewell is 63-64..model yr...On a diffrentt forum thay said this would run 40 + mph...I am going to Quit...
B,
After the carb rebuild..Engine runs fine..So we are working on brakes now..took old brakes and had them relined $128 bucks..OMG.. rebuilt master cyl.....rebuilt wheel cyl....I guess brake springs are color coded..haveing a hard time finding them..its got a dana rearend,,looking for 6" blue brake return springs...Look in your box of parts..B,
That engine was also a very popular marine engine conversion. The old Graymarine's were actually Continentals (I have a Graymarine '109' in a boat of mine that I think is the '226').
I'm also working on a Toro General. The serial number on my tractor was on the right side of the frame on the top just ahead of the dash panel. Mine in a 1964 Model # 37012, with a dump box and 6 cyl. Continental F226 Spec: 1578, SN: 122245. I'm checking at work to see if we still have any manuals for it, and will get back to you if I find out.
My brother had a 1963 Rambler with a flat head six in it. Kinda funny looking engine as I recall with the distributor coming out of the head. I have seen a lot of 4 cyclinder engines with the distributor coming out of the head on fork lifts.
Richard W. |
| Continental Red Seal Power Unit | DougM | Antique Gas Engine Discussion | 18 | 04-13-2008 11:52 PM |
| Continental Red Seal Power Unit Engine | Ben Dixon | Antique Gas Engine Discussion | 11 | 11-12-2007 07:41 PM |
| One way valve won't seal | Tim Venetis | Generators & Motors General Discussion | 2 | 03-02-2007 11:05 PM |
| Wisconisn VE4 seal | Neill | Antique Gas Engine Discussion | 3 | 10-19-2005 09:09 PM |
| red seal contintenial | Peteman425 | Small Air Cooled Gasoline Engines | 1 | 06-02-2005 08:49 PM |
