Waterloo Gasoline Engine Co. serial numbers
Well I'm a few days late posting this, but here are the up dated serial number lists of the...
this thread has 15 replies and has been viewed 1995 times
Old 04-08-2007, 07:35 PM
Greg Tyler Greg Tyler is offline
Default Waterloo Gasoline Engine Co. serial numbers for 1907 1908
Well I'm a few days late posting this, but here are the up dated serial number lists of the waterloo gasoline engine co, Again if anyone has an engine they would like to add I'd like to hear from you. Also I'm sure there are a few things that may not be 100% accurate. So if you see something that may need to be changed let me know.Greg.
Old 04-08-2007, 07:46 PM
Default Waterloo serial numbers 1909-1910
I think the first Eaton engine is on the 1909 list. If any of you guys in Canada or over seas have any engines you would like add I'll put an * after the number so we know the engine is some where other than the states.It would be interesting to see how many there may be, Greg.
Old 04-08-2007, 07:52 PM
Default Waterloo serial numbers 1911-1912
You can see theres begining to be alot more numbers now. The United engines are really starting to kick in. Thanks to Dick Weber for supplying a list of waterloo uniteds. Greg.
Old 04-08-2007, 08:01 PM
Default waterloo serial numbers for 1913-1914
It looks like the boys at waterloo were on overtime in this time period. Alot of different contract engines. When you look at the listings you get the feeling that sometimes a single engine taged as whatever was produced and at other times blocks of them say 10 or more were taged the same. Greg.
Old 04-08-2007, 08:12 PM
Default Waterloo serial numbers 1915-1916
While conversing with Dick Weber on the waterloo uniteds he noticed that the heyday for them was in the 1912-1913 period. But theres one on the list for 1915 and one for 1916. Possibly the united folks went back to WGE Co. to supply them with engines from time to time??? Or maybe WGE Co. offered some engines cheap to take the business back from the Asscoiated folks???? Kind'a interesting.Greg.
Old 04-08-2007, 08:17 PM
Default Waterloo serial numbers 1917-1918
It looks a big portion of WGE CO.s business is from the Majestic folks. Still a few Eaton's mixed in. Not as many numbers on record now. Greg
Old 04-08-2007, 08:24 PM
Default Waterloo serial number for 1919-1920-1921
Not alot of numbers for 1920, Only two. Wonder why???
Old 04-08-2007, 08:34 PM
Default Waterloo serial numbers 1922-1923
You can see the type h engines here with a few jd's mixed in. I'm not into keeping jd numbers but will have to start I guess. that may help determain how many h's and k's are still out there.Greg
Old 04-08-2007, 08:38 PM
Default Waterloo serial numbers 1924-1925
1925 is as far as I go. By this time its mainly JD engines but there looks to be a few Waterloo boy type H's mixed in yet.Greg.
Old 04-08-2007, 08:47 PM
Default Waterloo contract engine list footnotes
Here's a list of odd ball serial numbers and also a list of footnotes. Some of you guys may have an engine on the list or one thats not on it. If you do and you would like to add a footnote because of something unusual let me know. Greg.
Old 04-08-2007, 08:58 PM
Default Waterloo contract engine serial number list
Here's the list of waterloo contract engines and a list of the years produced. You'll need this in order for the following lists to make sence. If you ,, print these off then you'll have them, along with the following posts. I was having trouble posting them so Harry changed some things and made it possible to post these. Thanks Harry. I could only post two at a time though so there's a few posts to get through to get all of the information.I hope you waterloo engine enthusiasts enjoy this,, At the very least it makes for good reading.Greg.
Old 04-08-2007, 11:26 PM
JLB1111 JLB1111 is offline
Default Re: Waterloo Gasoline Engine Co. serial numbers for 1907 1908
Hello Greg I have a wonder gasoline engine h.p. 3 1/2 no. 33253 1911 model that you can add to your list the tag says wonder cement machny. thanks for the list you have been working on. J.L. Burkett Panama City Fl. THANKS
Old 04-09-2007, 12:27 PM
Craig Shinn Craig Shinn is offline
I have serial # 80350, tagged D. T. Bohon, 1 1/2 hp. Thanks for the work you're doing.
Old 04-09-2007, 01:45 PM
Doug Kimball's Avatar
Images: 71
Greg,
You have my contract engine listed ... 114,281. It has 3 1/2" bore& 5" stroke no tag but ser.# stamped on end of crank. Original paint(red) & Jaeger Machine Company decal. Speed control lever is stamped steel & moves in horizontal plane instead of the more common vertical, cast lever.
Old 04-09-2007, 09:14 PM
Thanks to you guys who have replied with your serial numbers. Also thanks Doug for identifing your Jaeger. I put a footnote on it with the info you gave me. I have a couple of big chiefs that have the speed lever like yours. I don't think they had them like that for to long. Greg.
Old 04-09-2007, 09:28 PM
Images: 71
Greg,
This is the photo I meant to attach.
Engine serial numbers and engine registries. Daniel Dorece Antique Gas Engine Discussion 8 01-06-2008 04:14 PM
Gas Engine serial numbers Chris J Antique Gas Engine Discussion 21 01-06-2008 10:58 AM
Waterloo Contract Engine Serial Number List Greg Tyler Antique Gas Engine Discussion 2 03-30-2007 08:01 PM
All Steam engine serial numbers KG1584 Stationary Steam & Traction Engines 7 02-08-2006 05:21 PM
Waterloo Gasoline Engine Co Stationary tractor engine hhound Antique Gas Engine Discussion 9 12-15-2005 11:10 PM
