Buzz coil question (Tom Thumb)
On the older non Ford type buzz coils in a box, there are generally four connections. Two on the...
this thread has 5 replies and has been viewed 1154 times
Old 04-26-2007, 02:19 PM
Images: 305
Default Buzz coil question (Tom Thumb)
On the older non Ford type buzz coils in a box, there are generally four connections. Two on the front side for the primary through the points and two on the top for the secondary.
My question is: which is which on the secondary terminals? Obviously one goes to the spark plug and one goes to ground, but does it matter which one? I'm sure some of the old coils were marked with labels on the wood, however, mine is plain.
One spark terminal is toward the top front point side and one toward the top rear. Maybe it doesn't matter and maybe one was the outside of the coil winding and one was from the inside. I would think the outside of the winding should go to the spark plug.
Was there any standard for locating these?
-- Harry Engines Videos
Old 04-26-2007, 03:29 PM
Jim Sherman's Avatar
Images: 84
Photo Re: Buzz coil question (not Ford)
See the picture here if this is the type of coil you are talking about. I used a jumper on the front top post to neg side. The back top post I put to the spark plug. I can't remember where I found this info but it works great.
Jim Sherman
My website
Old 04-26-2007, 05:49 PM
Elden DuRand's Avatar
Images: 6
Default Re: Buzz coil question (not Ford)
Originally Posted by Harry View Post
Which is which on the secondary terminals? Obviously one goes to the spark plug and one goes to ground, but does it matter which one? I'm sure some of the old coils were marked with labels on the wood, however, mine is plain.
Hi Harry:
Use either one and ground the other. If you have an even firing two cylinder engine, just run each end of the secondary to a plug.
Take care - Elden
Old 04-26-2007, 07:53 PM
As Elden said it should work either way. Until the wasted spark systems became polular, where they fire both plugs at the same time with the spark on the exhaust stroke being wasted, it was thought that the spark should jump from the center electrode to ground. On these systems it has to go in one plug and out the other. To find out the direction the spark is traveling you can hold a pencil point in a gap and let the spark jump across it. The downward side will have a sparkling trail by the graphite it carries off with it.
Old 04-26-2007, 09:29 PM
BWegher BWegher is offline
There is no electrical component with polarity, condensers work both ways.
The direction of high voltage does matter. The spark plug center electrode is designed to withstand erosion. If you run the spark plug backwards, the ground electrode will degrade, just like EDM.
Old 04-27-2007, 07:54 AM
Images: 305
Thank you for the ideas! I'm wiring up the Tom Thumb today.
The "wasted spark" type of coil sends a huge flame to the spark plug!
Buzz Coil Question Steve Holbrook Antique Gas Engine Discussion 2 02-16-2008 07:56 PM
Dry cell battery and buzz coil question Dave Beck Antique Gas Engine Discussion 9 02-03-2008 05:47 PM
buzz coil question David K Magnetos, Ignition Coils and Spark Plugs 3 01-18-2007 08:25 PM
Buzz coil or auto coil Don Nelson Antique Engine Archives 5 12-07-2004 05:08 AM
Ford Buzz Coil Question Chris Antique Engine Archives 1 04-17-2004 08:41 PM
