engines made from compressors
I would like to see engines made from old compressors If any one has any pictures, I would...
this thread has 19 replies and has been viewed 2076 times
Old 04-30-2007, 10:34 PM
Mac Leod Mac Leod is offline
Default engines made from compressors
If any one has any pictures, I would appreciate it if you would post them
Old 04-30-2007, 11:32 PM
Rick I Rick I is offline
Default Re: engines made from compressors
I saw one at the Canandaigua Pageant of Steam in 2006; it had a GREAT sound to it... see
http://www.oldengine.org/members/inz...made1_600.html
-Rick I.
Old 05-01-2007, 12:01 AM
That is a reminder, Mac.
HEY SMOKE!!! How is your engine doing ????? Have you been working on it or is the car taking all of your time ???
Jim
Old 05-01-2007, 12:06 AM
Dick Graybill's Avatar
Dick Graybill Dick Graybill is offline
This Maybe The Same As Previous Post. It Was Taken At Penns Cave Show A Couple Years Ago.dick. AFTER LOOKING OVER IT MIGHT BE SAME BRAND OF COMPRESSOR BUT DIFFERENT CONVERSION. DICK.
Old 05-01-2007, 12:27 AM
vicp's Avatar
vicp vicp is offline
I'm imtrigued with these engines made from Compressors. I was involved in the refrigeration trade back in the 60's and many of the belt driven compressors, Tecumseh, Brunner etc had eccentrics on the cranks rather than actual throw crankshafts. seems to me those wouldnt work very well trying to make an engine. Or are Air compressors equipped with cranks??
Just curious VicP
Old 05-01-2007, 12:56 AM
Vic
Are You are talking about the new style compressors. The older ones are an ideal unit to the make a h-t miss engine from. They have the crank, rod & pistion just like an engine.
I have an eye on 2 very small compressors to make an engine out of. Sure hope I can get them.
Jim
Old 05-01-2007, 06:01 AM
John Davis's Avatar
John Davis John Davis is offline
Photo Re: engines made from compressors
Here is a engine that my Dad made from a compressor a few years back. I believe he used a distributer shaft with 90 degree worm gears out of a voltswagon engine for the side shaft that the flyweights are attached to. He can tell you more about it then I can. Photo is not real good quality need to take some better ones.
Old 05-01-2007, 12:46 PM
Ned L Ned L is offline
I won't be converting it, but one restored compressor I have that would make a neat conversion is a small inline 4 cylinder craftsman compressor from maybe the 30's to 50's. The whole "block" is about 8" long and weighs about 5 pounds, it has a regular 4 throw crankshaft in it. - A neat little thing.
Old 05-01-2007, 12:52 PM
Ned,
How about posting a picture(s) of it? Probably a lot of us would like to see what it's like. I've never seen one like it myself.
Bill
Old 05-01-2007, 12:58 PM
I'll see if I can get some posted. (I have to take them first) Give me a day or so.
Old 05-01-2007, 05:27 PM
Dale Russell Dale Russell is offline
I have 3 of the engines made from older engines and Air compressors. I don't have any way to post pictures. An earlier post mentioned the gears from V W's. That is what the fellow that made mine used also, works great and is not to large of a gear. One one of mine he used the gears from an earlier B&S engine to operate the Ex. Valve. The other one is a side shaft. On the Compressors you have to make a spacer between the block and the head to create the combustion chamber. On compressors the piston comes too close to the head and there is no place for the combustion chamber. Each one is Unique and fun to play with. They also get a lot of attention at Shows.
My 2cents worth, Dale
Old 05-01-2007, 05:32 PM
Marty Hitzeman Marty Hitzeman is offline
As A Matter Of Fact I Just Picked Up A Vertical Running Maytag That Was Converted To A Compressor Over The Weekend At Auction. It Has A Small Air Tank With A Gauge And Water Seporator. The Funny Thing Is It Has 2 Elecric Motors Belted Together To Turn The Maytag Over Because The Compression Is So Strong. I Ran It The Other Day When I Got Home And It Worked, It Doesent Pump Up Very High But It Does Work. I Will Take A Pic And Post It.
Old 05-03-2007, 09:42 AM
Thank you for the pictures and advice...I just picked up an old compressor and have no need for it as a compressor, so I just wanted to get some ideas.
Mac Leod <also if there are any more pictures, please post them>
Old 05-03-2007, 12:11 PM
John Newman, Jr.'s Avatar
A few posts up there was talk of a 4 cylinder inline compressor. I have 2 of these. One on a complete running set up and the other purchased separately last year at Portland ($5 - no flywheel)
Here are a couple of pics of the complete one that I cleaned & painted. Has a Lauson RSC engine to drive it and a Campbell - Hausfelt (SP??) tag on the base.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 05-03-2007, 07:26 PM
vern0n vern0n is offline
I have an engine I made from a Curtiss compressor. I also used the VW gears and made a side shaft for it. I don't have a picture on this computer, but you can see it in the April 2004 issue of GEM to see it.
Old 05-04-2007, 07:47 AM
John, Yes, your compressor is exactly the same as my little 4 cyl Craftsman. Even the same base & storage tank. I just put a 'vintage' electric motor on mine.
Old 05-05-2007, 01:26 PM
Arnie Fero Arnie Fero is offline
Jim French is working on a nice open-crank "four poster" vertical H&M built from an old vacuume pump. Have a look...
http://www.oldengine.org/members/dol.../blackhead.htm
See ya, Arnie
Old 05-05-2007, 03:14 PM
Johnny Williams Johnny Williams is offline
OK my inerest is really peaked on this! Prolly a dumb question but are tere any "plans" or instructions out there on doig this?
Johnny
Old 05-06-2007, 07:56 PM
nar's Avatar
nar nar is offline
Images: 51
Here's one I made up a long time ago. It's not open crank but still kinda neat. It was a 2-cylinder refrigeration compressor a guy gave me at a show & had the eccentrics instead of the normal crankshaft. I had to make a new crankshaft & rods for it. The mag flywheel was off an old lawnmower engine with the fins turned off. Not sure what the other flywheel was off of. I was gonna use it in a go-kart but never got that far.
-nick
Old 05-20-2007, 06:42 AM
Coen Verwer Coen Verwer is offline
Nice compressors uh engines!
I am planning to make a model engine too, and looking for sideshaft gears..
What sort of Volkswagen has that sort of gears? Are that the gears for driving the ignition?
Coen
Gas engines made in Maryland HBurk Antique Gas Engine Discussion 1 01-09-2008 11:00 PM
Any Engines Made In St. Louis ?? kennyo Antique Gas Engine Discussion 7 12-18-2006 09:44 PM
Australian Made Engines Patrick M Livingstone Antique Engine Archives 1 08-05-2003 09:12 PM
Engines made from compressors Kevin Beitz Antique Engine Archives 22 11-19-2002 01:49 PM
engines made by Wm Foster ? mark foster Antique Engine Archives 0 08-15-1999 03:34 PM
