Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
maytag help
i am broght an magtag model 92 single cylinder . i was just wanting to know what trip the points...
this thread has 4 replies and has been viewed 1145 times
Old 05-01-2007, 08:28 PM
j ridings j ridings is offline
Default maytag help
i was just wanting to know what trip the points inside .
i don't see an cam lob any were. would like to see an picture of the pionts and coil hooked up . also the cam lob and where it should be thank u
Old 05-01-2007, 09:09 PM
Francis Francis is offline
Default Re: maytag help
J,
Go to this web site - it has drawings, including part lists, of Maytag engines
< http://www.maytagshed.com/engdraws.html >
Old 05-01-2007, 09:46 PM
thanks for the website but it is not the clearest and i can not make it out
Old 05-03-2007, 05:39 PM
can someone please help me out that website i got is very hard to make out.
i would also like to know where the spring gos thats hook up on the fly wheel.
thank u for your replies.
Old 05-03-2007, 10:33 PM
Here is another web site which may be a little clearer -
< http://www.oldengine.org/docs/Maytag_SM.pdf >
Look at the Side View Late Type Single Cylinder Multi-Motor drawing. Assy 3292 is the governor assembly and it is mounted on the flywheel. When the engine gets up to speed. the governor causes the points to remain open and no spark occurs. As the engine slows down, the governor will allow the points to operate and the spark will occur, and the engine speed is increased until the governor assembly causes the points to remain open.
On the outboard side of the flywheel, there is a cover held by two screws. Remove the cover and the governor assembly can be seen. There is a knurled nut (12828) which is used to increase or decrease speed. Tightening the knurled nut will increase engine speed and, visa versa, loosening the the knurled nut will decrease engine speed.
Will Maytag 72 power my Maytag washing machine. triplepass Maytag Engine Collectibles 9 11-13-2007 11:52 PM
Maytag FW-24 PAFLYER Maytag Engine Collectibles 3 05-02-2007 07:04 PM
Help Maytag mod. 92 Josh Downard Antique Engine Archives 6 06-15-2003 04:43 AM
MAYTAG Lynn Taylor Antique Engine Archives 0 01-28-2002 12:31 PM
maytag Terry Taylor Antique Engine Archives 1 01-20-2002 01:53 PM
