Need LP Solenoid Valve -- Onan 307-0312
this thread has 2 replies and has been viewed 3792 times
Old 05-16-2007, 04:29:50 PM
pcbye pcbye is offline
Email Not Working
Default Need LP Solenoid Valve -- Onan 307-0312
Greetings:
I am looking for a source for the OEM or equivelent of the Onan 307-0312 LP Solenoid Shut off valve to feed the Garreson KN regulator on my 15.0JC.
Any pointer would be surely appreciated. I did a few google searches and found one source for that exact part number for about $100.00. That seems a bit steep.
All my other searches yielded valves with pretty small ports 1/4" or so. The Garreson is fed with about a 3/4" pipe, so I think a matching valve would be appropriate since it is only 11" WC.
Best regards;
Peter
Old 05-16-2007, 07:00:06 PM
VaughnSimon VaughnSimon is offline
Default Re: Need LP Solenoid Valve -- Onan 307-0312
First, you can rest assured that Onan never had a factory that made gas valves. So you just need to find a standard part that will do the job for you. The valve on my CCK is 3/4" and may be exactly the same part they put on yours. I polished the tag as best I can. Here is what (I think) it says. EATON Electric. "G-LP VALVE". Model NG-1014-31B. 12 VDC, .5 AMPS., 5 (or .5) PSI. It is possible the "NG" is actually "NC". It is very hard to read, so take nothing literally.
Old 05-16-2007, 08:05:47 PM
Gunny Gunny is offline
Onan used a lot of ASCO solenoid valves too. WW Grainger would be one source. Try you local gas supplier, if they don't have them, they might be able to point you in a good direction.
Fuel Solenoid Valve P & H hwh888 Generators & Motors General Discussion 1 09-23-2007 10:13:07 PM
Does replacing solenoid require pulling the whole starter? (Onan DJE) ichudov Onan Generators 7 09-09-2007 09:09:26 AM
Cracked Valve Cover-Onan DJE B.Ikard Onan Generators 4 07-01-2007 02:27:10 PM
Onan 3DJA Stop Solenoid Burnt Out Gasman327 Onan Generators 17 11-15-2006 07:26:45 PM
Onan Demand Panel and starter solenoid Jim Kubicz Onan Generators 1 03-07-2005 09:10:16 AM
