Unseizing an engine
this thread has 54 replies and has been viewed 58173 times
Old 05-22-2007, 04:16:42 PM
sambear sambear is offline
Default Unseizing an engine
What is the best method to unseize an engine? I have tried diesel with motor oil, topped off with two weeks worth of daily doses of Lloyds 'Moovit' and that worked on an inline six 235.5cid GMC engine.
For a W-30 tractor, likely seized due to invasive moisture, would diesel be the best way to start? I think Lloyds 'Moovit' will do well, but what about SeaFoam 'Deep Creep' or automatic transmission fluid?
After that do I leave the tractor on a ramp, in high gear, and allow gravity to place pressure on all four cylinders?
Any success stories or suggestions would be most helpful.
Old 05-22-2007, 07:02:01 PM
Images: 12
Default Re: Unseizing an engine
All of the above sounds good. You might also loosen the rocker arms, make an air adapter from an old spark plug so that you can leave a few psi of compressed air in first one cylinder and then another to help the oil penetrate. Maybe some other tips will come along.
Old 05-22-2007, 08:19:49 PM
I remain convinced that brake fluid is the way to go.
The air pressure thing works well and it takes ONLY a few pounds.
Give it time.......
Old 05-22-2007, 10:45:29 PM
Someone ain't gonna be happy with me posting this I'm sure, but....in my years of working on old seized engines, to me nothing works better than unhooking the con rod, taking a block of stove wood that fits fairly tightly in the cylinder bore, and wailing on the block of wood with a sledgehammer. (That's how we usually HAVE to unstick these rough ol' Southern tractors I'm used to working on!!!!!!) In the rare cases this hasn't worked, I've filled the bore with brake fluid and lit it off and let burn for awhile before pounding again. (Brake fluid burns good and slow.) I've seen you can soak forever sometimes with nothing doing 'til you use a little (or lot!) of brute force.
Good luck, and glad to hear you're opting to restore the family tractor!
Mike M
Old 05-23-2007, 12:03:36 AM
Farquhar Farquhar is offline
If at first you don't succeed, just git a bigger hammer!!!!
My motto too, Steamdaddy.
I am going hafta do some soakin on the F/M dishpan though, got it all but the piston, the cylinder has got a "lil" too much rust to frail the piston out just yet.
Old 05-23-2007, 12:14:30 AM
Exclamation Re: Unseizing an engine
i used to make my own 'bust it loose solution = 1 cup gasoline, 1 cup kero (or substitute #1 fuel oil), 1 cup type F trans fluid, and 1 cup -Liquid wrench. Mix thoroughly with a wood spoon, and pour in top of the cylinder, and let sit. You can pressurize with air, if the cylinder is closed, if it isn't, seal it off. KEEP AWAY FROM ANY IGNITION SOURCE. VERY FLAMMABLE/EXPLOSIVE
DO NOT try to break it loose by towing and dropping the clutch You may end up busting the rods, and possibly bending the crank. One of the guys bought a parts tractor, last year, that he was told was lightly stuck. He tried this very thing, with a friend towing the old ford with a JD. When he popped the clutch, several things happened in a hurry. First a loud CRACK was heard, followed by several ominus crunching noises that sounded a death knell for the 4 banger. Next, the ford slammed to a stop, throwing the driver against the steering wheel, with a lot of force, As all this nonsence was going on, the JD was trying to stand on it's head. Thankfully, the JD driver somehow managed to ease off on the clutch, allowing every thing to come to rest gently. The damage, you ask? 3 busted rods (the one bent at a right angle, busted out the cylinder, the water jacket, and made a mess out of everything!), broken cam, Twisted crank shaft, and a crank bearing busted out of the block
Old 05-23-2007, 11:41:27 AM
CaptainJohn CaptainJohn is offline
I use liquid wrench. Tapping on engine to set up a viabration helps too. It may take several days. But all of a sudden it will free up. good luck with it. Capt,n
Old 05-23-2007, 11:51:33 AM
Cap:
Do you add Liquid Wrench daily or just spray it in once?
By "vibrating the engine", to what procedure where you referring? Do you mean rocking the tractor or tapping each piston?
I have dumped diesel into each cylinder, sprayed 'Deep Creep' and poured a cup of automatic transmission fluid via the spark plug holes. Do I need to have each cylinder consistently topped up?
Old 05-23-2007, 01:16:44 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
When my father and I are working on an engine with stuck pistons, we usually take the heads off and clean the cylinders up first. This allows us to inspect the condition of the liners, makes it a little easier to turn (inevitably when one cylinder is going down another is coming up) and prevents any further damage which could occur due to trapped debris. Otherwise we use regular ag diesel with a little not so friendly persuasion . If that doesn't work we light the diesel, let cool and try the persuation again.
We do have an engine which we will not be able to follow these processes. We have a four cylinder engine which does not use heads. Instead it is a blind bore. To make maters more interesting, the only openings in the head end are over the valves, meaning we cannot even see the top of the piston. Any suggestions?
Old 05-23-2007, 03:00:43 PM
Patrick McNallen Patrick McNallen is offline
Talking Re: Unseizing an engine
You might try a pressure washer on that headless engine. If you can get the wand tip into a spark plug hole or valve access hole, it will blast out most anything loose. Then you can inventory the rust, bugs, carbon, and other debris from the cylinders after you get it out of your eyes.
Old 05-23-2007, 04:02:50 PM
Seems like a lot of effort (and trust) is placed in a slow burn and persuasion. I am feeling anxious about setting any combustible material alight, especially given this tractor rests in a open area of a bluff.
Persuasion, this must come after the rods are disconnected from the crankshaft(?).
No tugging by another vehicle while in gear, I agree.
Old 05-23-2007, 04:04:16 PM
I lost my Grandfather (the original owner) when another tractor pinned him on a hillside; I forgot to include that reason as to why I feel very emotional about working on this W-30.
Old 05-23-2007, 04:19:44 PM
Originally Posted by sambear View Post
No tugs while in gear, I agree. I lost my Grandfather (the original owner) when a tractor pinned him on a hillside;
My God Man, tow the tractor to the shop and remove the engine for the needed repairs.
The people that responded to your request has given you very good advise !!!! Please follow their info.
We, they, have done this so many times, we are just telling you the best way to get the engine loose.
Jim
Old 05-23-2007, 05:08:47 PM
Jim
Jim, Sambear might be one of those fellows who prefers to work out under a shade tree like me....of course I'd prefer a shop if I HAD one....but haven't had the money to spring for one yet! I might if I'd quit buying old "junk"!
Mike
Old 05-23-2007, 08:40:26 PM
Eric M. Eric M. is offline
For loosening rusty stuff in general, I'm a staunch believer in kroil. www.kanolabs.com If possible, you might want to take the heads off and wirewheel the inside of the bore (if the pistons aren't aluminum) paying close attention to the junction of bore and piston. That will help whatever you use to penetrate where it is needed. If the pistons are aluminum, they might have swelled, and you can easily damage the block if you try to force them out. In that case, your only option is to break the pistons and buy new ones.
Old 05-23-2007, 08:48:38 PM
I add more as it creeps in and evaperates. Differant objects set up a viabration when struck with tools. You got to experiment there. Just like a bell when struck has vibes. There may be sonic vibrators for this??? Like sonic waves to clean parts. Hope this helps. Capt,n
Old 05-24-2007, 09:11:42 AM
Sambear, You did not say what your intentions were for this engine. I think the amount of time it has been stuck, and the amount of moister involved will make several of your decisions for you. If you wanted to "get er loose & runner quick", that would likely be a mistake. There are probably Valves that will not seat again, and rings that are stuck tight in the ring lands, even if you got it loose it needs to come apart. My advice is to make sure you want to do it, then haul it in and tear it apart. There are several ways to get the stuck pistons out once it is apart, but the family tractor needs to have a complete valve job, cylinders, pistons, and rings need to be prepared. Crank journals, and bearings inspected, and checked for oil clearence, and if this motor has water in the oil DO NOT OVERLOOK the large roller main bearings. If these bearings are pitted, they will haunt you with an obnoxiuos grinding noise for the rest of your life
Your family tractor, and your grandfathers memory should be honored with an investment of time & money (if you live to be 70+, whats a year & $2000.?) besides it will all come back to you and yours on sale day if it runs good
Old 05-24-2007, 01:39:41 PM
I agree with Tony (and others) that moving the W-30 tractor into the garage is very important for its restoration. Alas, until that can be arranged, I have to keep up the efforts under the prairie sky.
Most of this preliminary work is dedicated unseizing the engine and cleaning out as much 'crap' as I can before it is trailered to my home.
The ideas presented by everyone are very appreciated. Much, have I, to think about as this process continues.
Old 01-09-2008, 10:03:12 AM
Dale Jass Dale Jass is offline
We are trying to free a IY-69 continental dad bought somewhere around 1950 and it was stuck then.Dad used it for a long time on the bale elevator or putting ear corn in the crib. We now have it at home for a 4 H project my son has it soaking but it seems really stuck again. I gave him a can of Kroil and a can of PB Blaster, one piston is pooling to the top of the plug hole the other three are taking fluid so we asume the one piston is at fault. We have a make shift arm with weight hanging off the pto for constant pressure and we pry a little everyday but its been a month of this and no progress yet. I found a manual for it but we really dont want to tear her apart yet any more Ideas as to what to do? Is NAPA a good source for parts for this motor if we need to pull the head?. Also any other info on this motor would be great if someone had it. We think its off a model 52R IH combine infact were positive dad took it from one and the pto is diferant then the baler model. Thanks for any input.
Old 01-09-2008, 10:39:19 AM
You might try draining the crankcase and turning the engine upside down, then pouring the oil and penetrant mix back into it. That might allow the penetrant to access the stuck parts better by seeping around the piston skirt and thru the oil drainback holes around the oil ring and into voids around the wrist pin, etc. This may help penetrant reach the valve guides, too. If the engine has a starter ring gear, prying on it with a large screwdriver, first in one direction and then the other, may loosen the engine. If you get it to move, it will probably only move a fraction of an inch. Moving it back and forth over a period of days, a little farther each time, will usually allow it to turn over after a week or so. Leave it upside down to soak in between working on it. When you try to turn the engine, remove the spark plugs, since some cylinders will probably be oil-locked. Look for rust and crud in any oil that runs out of the cylinders.
