6 Volt system Generator output
Hello,...i need help again...could anyone assist me in this..perhaps? ...
this thread has 8 replies and has been viewed 2766 times
Old 05-29-2007, 12:22 AM
Sky's Avatar
Sky Sky is offline
Images: 45
Question 6 Volt system Generator output
http://antiquetractorforum.com/viewtopic.php?t=2274
20th Century Machine's http://www.youtube.com/user/VintageClassic1
Old 05-29-2007, 08:34 AM
Default Re: 6 Volt system Generator output
you should be able to just put your meter on the pos, and neg battery posts and get a reading.try it with motor off, then start and see if it goe's up, mabe rev it up a bit and see how much it increases.it's been awhile since i checked a 6 volt but i think it should go to 7-1/2 volts or so.hope this helps.
Old 05-29-2007, 09:22 AM
Elden DuRand's Avatar
Images: 6
Grub:
7.5 Volts is a bit high. A good target to aim for is 2.3 Volts per cell or 6.9 Volts for a 6 Volt battery.
Any higher and the battery will lose water quickly and may not last long.
Take care - Elden
Old 05-29-2007, 11:37 AM
Jester Jester is offline
Considering Sky's wording, I believe you answered half his question, fellas. Since you suspect the ammeter is bad, Sky, I am assuming you are wanting to also check gen. amperage output. Grub and Elden have both offered good help for checking voltage output--while that will help you determine that your charging system is strong enough to maintain battery voltage, be aware that amp output is equally important. Without knowing the specific limits of your gen./reg. configuration, I can tell you that most 6 volt charging systems that I am familiar with are designed to deliver between 25 and 45 amps. It also wouldn't hurt to check all connections, especially grounds, on the gen./reg. curcuit. My experience with 6 volt electricals has been that all kinds of wierd things can happen when something has a loose or dirty ground. If you haven't checked it yet, that might be the only thing wrong with the ammeter. Best Wishes
Old 05-29-2007, 09:47 PM
Bill Geyer's Avatar
Images: 11
OK Sky, I think the box on the generator is a cut out. It only has two connections right. All it does is sense the voltage. If the generator is producing more than about six volts it should pick up and connect the generator to the battery. When the engine is turned off and the generator is no longer making electricity, the relay will open. This removes the generator from the circuit so it won't run down the battery. I don't think your car has a voltage regulator or a current regulator. I think the generator has a third brush that is set for about 12 amps high or with lights on, and about 4 amps on low with lights off. I have never worked on a car like that but have worked on tractors with that system. This system will not charge at idle, you will have to speed it up a little 1000 - 1200 RPM. You can put a jumper (alligator clips) across the terminals of the cut out this will put the generator in the circuit, and it should charge and give an indication on the amp meter. Also with your meter on the battery the voltage should rise. But that may take some time.
May the Stak be with you
Bill
Old 05-29-2007, 11:14 PM
Sky's Avatar
Sky Sky is offline
Images: 45
ok, yea, your right Bill. it makes sence becouse this is my findings.
now with the engine not started and a test with the multimeter directly from the battery, the battery reads 6.19 so i guess the battery is fully charged?
and the cutout reads 6.20 now with the engine running at idle, the cutout reads 5.79 to 5.80 it flickers back and forth from 5.79 to 5.80 so i guess it's doing it's job. now a direct test from the battery with the engine running, the battery reads 6.14 now that would be a drop 5 point becouse of the coil now pulling on the battery to run the engine. and when you give the engine some gas, i held the accelerator to like a "street speed" if you were driving the car, and readings from the battery jump from 6.29 and slowly and steadily climb to 6.48 it may have made it to 6.50 if i would have gave it more gas but i didnt want to do that. so from my findings, the charging circut must be working quite well. so what do you think?
Old 05-30-2007, 08:58 AM
yeah i was thinking on the lines of a 12 volt systym.like i said it's been awhile....
Old 05-30-2007, 06:14 PM
Bill Geyer's Avatar
Images: 11
Yes Sky, that all sounds correct, I think it's working fine. Sounds like your new tester just earned it's keep
Bill
Old 05-31-2007, 02:05 AM
Sky's Avatar
Sky Sky is offline
Images: 45
ok. Thanks guys! you been a big help
6 volt turn signal system Sky Antique Autos and Trucks 2 01-10-2008 12:11 PM
Aircraft Generator No Output! SteveL Generators & Motors General Discussion 18 01-09-2008 04:51 AM
4.0BF 186 volt output biggerred Onan Generators 1 01-03-2008 10:49 PM
Need batteries for 32 volt system steam Generators & Motors General Discussion 14 05-30-2007 06:50 PM
No output, AC generator Arthur Generators & Motors General Discussion 1 02-24-2005 12:12 PM
