Please help: Old Winpower brush-type generator/starter wiring
this thread has 1 replies and has been viewed 2812 times
Old 05-30-2007, 02:49:27 PM
norcalpablo norcalpablo is offline
Default Please help: Old Winpower brush-type generator/starter wiring
I recently purchased a 10KW Winpower driven by a big old Lister HA-2 two-cylinder air-cooled diesel. I got it started last weekend, and it runs pretty well, settling down at 1825 rpm. I understand engines, and can deal with fine tuning that part, but I’m pretty lost regarding the generator end. I believe that this unit uses DC windings and a commutator both for starting and maybe to excite the generator field? I can spin the engine by connecting 24 vdc to one of the wires, and grounding the other side. In addition to the commutator, there are four slip rings, but I think they’re connected in pairs. I have no diagram, and there are just several leads sticking out of the generator end. Any ideas on identifying the leads? What do you think the DC starting voltage should be (the leads are pretty small, making me think maybe it wants even more than 24 volts?). Do I need a voltage regulator, or is there a simpler way to control output? I’d like to keep the costs down, as I’m just playing with this unit. Winpower says they have no info other than it was made in 1961. Thanks for your help!
Paul
Model Number: D10018HA2AE4-SPT
Serial Number: U853-1
Single Phase
10 KW
115/230 VAC
Old 05-30-2007, 10:52:20 PM
Default Re: Please help: Old Winpower brush-type generator/starter wiring
May be your lucky day! Winpowers seem to be coming out of the woodwork
http://www.smokstak.com/forum/showthread.php?t=37884
Maybe you and Joe can swap information. As I remember he was needing engine information and you need electical, so maybe between the two machines you can find out everything.
Brush Arcing on DC Generator G Sams Generators & Motors General Discussion 5 04-24-2007 11:08:00 PM
wincobrush type generator wiring help? frazzled Generators & Motors General Discussion 12 12-06-2006 03:08:46 PM
Winpower PTO generator-motor? Wayne 440 Generators & Motors General Discussion 3 01-28-2006 11:22:18 PM
Regulator for Onan brush type gen set 25KW Scott Jones Onan Generators 3 07-11-2005 06:08:47 PM
winpower ac generator HELP! please. jay Generators & Motors General Discussion 1 05-04-2004 10:35:12 PM
