Go Back   SmokStak > SmokStak® General Discussion > Computer, Camera and ISP Problems
HP Printer/scanner/copier/fax
When we got the new puter we also got a HP 5610, all of it works but the scanner, it shows an error...
this thread has 6 replies and has been viewed 653 times
Old 07-08-2007, 07:40 PM
Cody C's Avatar
Cody C Cody C is offline
Images: 5
Default HP Printer/scanner/copier/fax
When we got the new puter we also got a HP 5610, all of it works but the scanner, it shows an error on the small lcd on it it says: No scan options. Any ideas?
When you dont understand people using big words, just nod and smile.
Cody C
Old 07-10-2007, 01:00 PM
Default Re: HP Printer/scanner/copier/fax
Per our chat, Cody, I think you got POJ (piece of junk)......
Get it exchanged before it's too late..................
Old 07-10-2007, 01:11 PM
Cody C's Avatar
Images: 5
It was a floor model and the have a no return policy on them.
Edit:
I had to download the drivers because the disc covers 98 2000 me and xp only. I also tried this with an older computer, same problem.
Cody C
Old 07-10-2007, 03:17 PM
Cody.......................BUMMER!!!!!!!!!!!
Try going the manufacturer's website and see if there are updated drivers.
Check your current driver version FIRST so you don't waste time downloading the drivers you already have..............
edit: This JUST dawned on me!
Your NEW pc is running VISTA!
Look for Vista drivers..............
Old 07-10-2007, 06:01 PM
Fred M. Fred M. is offline
Cody-
You may have recourse if you used a credit card to pay for it, regardless of their policy. It should have a new warrantee, so any defect will be repaired by an HP authorized service station.
HP has on-line forums for their products, so you may be able to get advice there. It could be as simple as downloading new drivers, or perhaps resetting the CPU.
Fred
Old 07-10-2007, 09:24 PM
Capt,n John Capt,n John is offline
If you have a insallation disc for the printer...try removing and re-insalling it. Capt,n
Old 09-07-2007, 12:54 AM
MarylandSteam MarylandSteam is offline
Hopefully you still have it... I found a post here http://www.runqa.com/scanners/94-scanners.html that mentions a simple fix for your problem, the quote is below.
"Basically, I am trying to use the scan feature but an error message occurs - "No Scan Options" which leads me to believe I need to be connected to a network/server. Any help would be appreciated.
Answer:
You need to go into the HP Solution Center that was installed with your drivers and set the "Scan To:" options. I was having this same problem and setting those options fixed it.
Of course you can as long as its connected to your pc. The images you scan will then go directly to your pc.
Sounds like either your rpinter drivers or the software that came with your printer is glitched or not installed.
Check this link for Drivers and Software that should hae came with your printer"
Printer troubleshooting Jerry B Computer, Camera and ISP Problems 1 04-02-2008 02:47 AM
OT printer Ihorse Smoke, Flames & Gas (Off Topic) 2 02-04-2007 05:17 AM
Scanner Initiation Fenwood52 Antique Engine Archives 0 12-28-2001 10:25 PM
scanner problems larry harding Antique Engine Archives 3 02-07-2001 05:47 PM
