Compressor oil type?
this thread has 11 replies and has been viewed 87738 times
Old 07-11-2007, 07:23:07 AM
Renee Renee is offline
Default Compressor oil type?
I want to change the oil in my old air compressor and would like to know what grade of oil I should use in the crank case. It is an older two cyl. Binks model 33 52 3 with an internal oil pump and powered by a 1hp electric.
Thank you in advance for your reply.
Renee
Old 07-11-2007, 03:04:23 PM
ListerDiesel's Avatar
ListerDiesel ListerDiesel is online now
Default Re: compressor oil
Going from when I had a large truck workshop to run, we had a special compressor oil for our big 3-cylinder machines.
Ours was a Shell product, but Texaco, Exxon and other makers also made an equivalent. It may have been Shell Vitrea?
Talk to your local wholesaler for oils and see what he can offer, we used a 30SAE grade in ours.
Peter
Old 07-11-2007, 05:33:39 PM
Images: 12
Look in the WW Grainger catalog, in the compressor section. Last time I looked they were selling Mobile. One SHOULD use compressor oil. I never have. I use 10-40 Quaker State engine oil. My 2 stage Speedeair (or however you spell it), gets run 5 days a week, it's 12 years old. I change the oil every year or two. Now the folks that know all about oil will start in about oxidation and all kind of mysterious differences between compressor oil and engine oil. Then the folks that know even more will tell you that this brand is better, or better use synthetic and how one brand of oil ruined his engine.
Now I agree that compressor oil is the proper oil and certainly will give one peace of mind knowing one is using the correct oil for the application. There is nothing wrong with that, it is indeed the wise thing to do.
It's just that the instructions that came with the unit were so emphatic about using their oil, I just wanted to see what would happen if I used what I consider a reasonable and good substitute.
I also used engine oil in Quincy and other brands of compressors at work, with no problems.
Guess I got a little out of hand here, but just wanted to share my
experiences
Old 07-12-2007, 01:27:48 AM
John G. Simpson John G. Simpson is offline
Email Not Working
Most compressor oils are just non-detergent, since there is no combustion residues to contaminate the oil.
Old 07-12-2007, 11:39:46 PM
Ed Bays Ed Bays is offline
Howdy Folks, I am a long time reader but seldom contributor, but you hit upon something I know about. The rule of thumb is.........if it has an oil filter use detergent oil, if not use non-detergent. We have a number of pre 1920 tractors as well as a 1919 Model T. The thing to remember is on the non-d engines, warm them up before an oil change. The purpose of detergent oil is to suspend the foriegn particles (cumbustion and normal wear) so they can be filered out by the oil filter. With a nondetergent oil, the particles will settle to the bottom of the pan and stay out of the wear path (in theory). Also, when buying compressor oil at the local Wholesale Tool, compressor oil is labeled "Air Compressor Oil", and footnoted "SAE ND30". Hope this helps.
Old 07-14-2007, 01:53:00 AM
My compressor said to use hydraulic oil. Idon't know where the manual is right now. The idea behind hydraulic oil is that it handles water well. I wouldn't use regular engine oil because the water will mix with the sulpher in the oil which makes a grayish slime. This chemical change creats a small amount of sulpheric acid. Ever tear doen an engine that's been sitting for years and see the acid etching at the oil level in the pan and on anything else that's goes down into the oil.
Richard W.
Old 07-17-2007, 12:16:44 AM
I know for a fact, in aluminum compressors at least, non-detergent oil must be used.
Several years ago we sold a quite expensive SpeedAire 2 stage compressor and the directions stated DETERGENT oil.
I knew that couldn't be right but who's to argue with the manufacturer?
Long story short the compressor was shot within a short time and I called Grainger as it was under warranty and reminded them of the oil recommendation in the owners manual.
They replaced the pump, no questions asked, and said that was a misprint in the manual.......
Old 07-21-2007, 06:09:31 AM
John A John A is offline
I have always used a good quality, name brand, Non Detergent 30 weight oil in all my compressors.
This ranged from Blackmer and Corken LP Gas compressors in the plant to our Speedaire, Kellogg, and other air compressors large and small.
Never had any oil related problems.
John A.
Old 09-19-2007, 09:07:49 AM
K D Redd K D Redd is offline
Default Re: Compressor oil type?
I just read this post, so I will put my 2 cents in. A couple of years ago our Volenteer Fire Deptment bought a compressor to keep the air brake up on the trucks. I forget the brand but it is a Cast Iron pump. The recommended oil was DIN 100 compressor oil. The second choice was Mobile 1 10W-30. I have a couple of DeVillbus pumps that the book said use 20W-20. I have changed to the Mobile 1 and I see easier starting in the winter and Lees oil consumption than with the 20W-20.
Kent
Old 09-19-2007, 09:54:02 AM
Ron Beddome Ron Beddome is offline
I have a compressor that also has to start in frigid temps, my question is has anybody seen non detergant oil in a synthedic make for sale any where. It would save me a lot of time , not to have to heat the compressor up before starting it !
Old 09-21-2007, 01:53:54 PM
Redwing Redwing is offline
My older big Worthington compressor with 25hp in high speed. and I uses Non Detergent 30 and it been run for over 15 years hard running at my old job then moved to my shop. until finally it got seized happened about few months ago it was I forget check oil level. I apart and loose up one of 2 rods and took to honing it and still good. rod is all alum.
Old 09-22-2007, 08:49:07 PM
Ron, Synethetic oil is detergent but the compressor I set-up for the fire dept. I just remembered was a Chambell-Hasfeld They spec. Mobile ONE 10W-30 as a second chioce of oil so they were not to concerned about the detergent or it being a multi-visocity.
Kent
Need help with an air compressor Joseph Musser Antique Engine Archives 2 11-01-2004 07:16:45 PM
air compressor Tom Hicswa Generators & Motors General Discussion 4 09-23-2004 09:08:03 PM
compressor? L.D. Antique Engine Archives 0 10-07-2002 10:19:11 AM
Compressor? REB Antique Engine Archives 15 05-30-2002 09:29:57 PM
