Possible Briggs oil sump/pump
Wondering if someone out there could help me identify what I believe to be a briggs oil pump. Its...
this thread has 7 replies and has been viewed 802 times
Old 07-16-2007, 11:58 PM
James Wallace James Wallace is offline
Default Possible Briggs oil sump/pump
Wondering if someone out there could help me identify what I believe to be a briggs oil pump. Its mounted on a steel plate(like one of those that separates a lower gas tank from an oil sump; with what looks like an oil pump on it for one of the older briggs F series engines. It has a what looks like a bronze L shaped pump, soldered on at 3 points. The pump has a round "tower" like 2 inches high by probably 1/2 inch wide with a spring and solid steel pin that acts like a piston... The lower part is a square made of a filter mesh around the base; on the top of this part is a small, long cotter pin holding a b.b. in place. I'm guessing its probably for an FB or FC; any ideas? I'll try and remember to get photos when i'm at the shop. Thanks, James in Wisconsin
Old 07-17-2007, 08:12 AM
Craig DeShong's Avatar
Craig DeShong Craig DeShong is offline
Images: 140
Default Re: Possible Briggs oil sump/pump
A picture would definitely help
Old 07-17-2007, 04:31 PM
Bill Geyer's Avatar
Images: 12
Sounds kind of like the one used in the old Jacobsen four stroke.
May the Stak be with you
Bill
Old 07-17-2007, 05:27 PM
If I remember correctly the FB oil pump is a small trough with a piece of steel that stick up and and had a spring underneath and it is actuated by the cam gear. I have only had my engine apart once, this is how i recall it being. FI engines use a sort of L shaped oil pump but they are fasted to the base with screws not soddered.
~ Jonathan
Old 07-18-2007, 12:03 AM
Here is a photo of that sump, 3 solder points underneath. There is under that pin thats protruding a spring, sounds like its probably for an FB eh?
Old 07-18-2007, 01:04 AM
James, got your email thanks. Yep, sure looks like an FB pump to me. If I remember correctly the FC and FE style were the same, a tall skinny trough with no pump and a long dipper on the rod. My FB had the tower broken right off on the pump and it looked the it blew a rod at one time because it broke the leading edges out of the trough. I converted it to the much better FH style system which is better for running long periods at shows and you cant tell unless you open the engine up.
Old 07-18-2007, 01:17 PM
It looks like the one that is in my FB engine also, nice find.
Old 07-18-2007, 05:18 PM
Bill Geyer's Avatar
Images: 12
Not a Jacobsen. I think Jonathan, and Moto have it right.
Bill
Briggs FI Oil Pump James Wallace Small Air Cooled Gasoline Engines 5 01-25-2011 07:49 PM
Briggs FH Oil sump/pan is rusted & rotten. James Wallace Small Air Cooled Gasoline Engines 8 12-01-2007 10:31 PM
Briggs FI oil pump woes Bob Kurtz Small Air Cooled Gasoline Engines 5 08-24-2007 07:34 AM
Briggs WM with oil pump Mike S Small Air Cooled Gasoline Engines 5 09-19-2005 12:55 AM
IDEAL enclosed crank oil sump question John Drabik Antique Gas Engine Discussion 2 05-22-2005 09:48 PM
