Go Back   SmokStak > SmokStak® General Discussion > Computer, Camera and ISP Problems
Ipod issues
Hi Guys, just wondering if anyone else is having issues with there Gen5 IPOD...
this thread has 6 replies and has been viewed 513 times
Old 07-27-2007, 08:35 AM
Roo Roo is offline
Default Ipod issues
Hi Guys,
just wondering if anyone else is having issues with there Gen5 IPOD restoring from itunes?
I cant get mine to restore even after Itunes says it has done so it just tells me I have to restore it again
ROO
Old 07-27-2007, 10:41 AM
John Herald John Herald is offline
Default Re: Ipod issues
check the Mag timming and clean the plug!
Old 07-27-2007, 07:01 PM
Roo Roo is offline
Question Re: Ipod issues
Good one John!!! this is the problem with something we NO moving peices!
Old 07-27-2007, 10:48 PM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is offline
Images: 1
Roo I think you have to scroll to left about 15 degrees before top dead center and then to the right just before bottom and then I lost.
Old 07-28-2007, 01:30 AM
vern0n's Avatar
vern0n vern0n is offline
Sounds like a case of really bad muffler bearings. Also you might want to see how much blinker fluid is in it. Sometimes a kanuiter valve will cause this. The best way to check it is to run a jumper wire from the toaster element to the mainspring armature. After that, measure the polarity of the ejecter slide pulley. If it is more then 13.56 millajewls, you must readjust the framming jamice to the desired 43.78 > Mhz of amplatude modulation. Next take a 9/14 condenser socket and meander the latatude switch to the north 4%. Peice of cake! Wait, did you say Gen 5? My mistake, those were the directions for the Gen 4. Never mind. OK, you will have to sashay the crank stoker .......
Old 07-28-2007, 02:26 AM
John G. Simpson John G. Simpson is offline
I have a 4th gen Ipod. it hangs over my belt. it has been loaded with belch music.
Old 07-28-2007, 06:34 AM
JKWidener's Avatar
JKWidener JKWidener is offline
Images: 26
See this link Roo, http://www.zolved.com/guruconnect/sh...e_same_message_
It takes only a moment to say I love you and a lifetime to say goodbye.
Timing issues 3HP FM Z Dan Sullivan Antique Gas Engine Discussion 3 08-03-2007 10:58 AM
18R wiring issues bkahler Onan Generators 5 10-29-2006 08:23 PM
Paint Issues Larry Carlston Small Air Cooled Gasoline Engines 17 09-01-2006 12:13 PM
Governor issues ryan68bug Small Air Cooled Gasoline Engines 2 07-19-2006 08:46 PM
