Calling all Fageol engine experts!!!!Hi Folks, Not real sure where this thread should go so I'm putting it in here for starts. I have...this thread has 2 replies and has been viewed 883 times
Hi Folks,
Not real sure where this thread should go so I'm putting it in here for starts. I have no idea what this engine was in so... I have a 21 HP 4 cyl Fageol gasoline engine made by Fageol Products Co., Kent, Ohio. Model 306845, ser. #150529. Rated HP is 21 at 3,600 rpm. Bore is 2-1/2" stroke is 2-1/4" (?) It is a headless design with the cylinders and head cast in one part. It has an over head camshaft that is driven by a vertical shaft geared to the crank. The crankcase is cast aluminum and is double partitioned. Engine lube oil is in one section and coolant circulates through the other. Could this possibly have been an oil test engine? The mag is a Wico XVM with shielded ign wires and plugs and has build date of January 1956. I want to find out about this engine. I know it is missing several parts. Any Fageol experts out there???? Thanks to one and all!
"May your walk through life have no dogpiles in it" -Brian Lynch |
Did a little detecto work and found out this was a Crosley engine. It's an Aerojet marine engine....it went in a boat.
did you buy that engine at the Allegany show?
if you did it's from a jet aircraft starter genset from the 50's |
| Calling All Rumely Experts | Eric Best | Antique Tractors - Old Iron Lugs, Cleats and Tracks | 38 | 07-29-2007 10:51 PM |
| Calling All I.H.C. Engine Owners | Jordan | Antique Gas Engine Discussion | 159 | 07-28-2007 01:54 PM |
| Calling all experts | Dan Dyman | Stationary Steam & Traction Engines | 2 | 07-24-2007 08:57 PM |
| any reo engine experts out there | oxthompson | Machine Shop and Tool Talk | 10 | 06-20-2007 10:25 PM |
| Any Stirling Engine Experts Here? | Tom G | Antique Engine Archives | 2 | 11-01-2004 12:39 AM |
