Can you weld the top of a piston?
this thread has 7 replies and has been viewed 3595 times
Old 07-31-2007, 06:39:33 PM
Steve Page Steve Page is offline
Default Can you weld the top of a piston?
Recently picked up a Cushman Cub 2Hp.
I need to find some valves and mabey a
piston.I was told the piston might be
able to be whelded??????
Old 07-31-2007, 06:47:21 PM
KeithW's Avatar
KeithW KeithW is offline
Default Re: Can you weld the top of a piston?
Aluminum pistons can be TIG welded. I've got a friend that made pocket money back in the day welding up holes in 2 stroke dirt bike pistons. They are usually an alloy called Lo-ex, low coefficient of expansion. Broken pieces from another piston is the best thing to use for filler. Just don't ever sand blast one. The sand embeds in the surface making thousands of little white hot sources of ignition as it runs.
keithw
Old 07-31-2007, 08:16:24 PM
Skip Landis Skip Landis is offline
steve, i have welded whole new heads in cast iron pistons with very good results. skip
Old 07-31-2007, 10:20:44 PM
vern0n's Avatar
vern0n vern0n is offline
I covered the top of a cast iron piston in brass. I haven't run it much, but so far no trouble.
Old 07-31-2007, 11:04:10 PM
Chris Hibshman Chris Hibshman is offline
Steve,
I have welded cast iron several times with an arc welder. I found that 6013 rod does a very good job.(Im sure other welders on this forum may disagree with my method) But after useing Nirod time after time....CRACK!!! Nirod has a high nickle content and even when preheating,slow cooling,Going by the instructions....Crack...
Good luck with you cushman. Is yours a R-14?.. I just got mine running.
Old 07-31-2007, 11:41:42 PM
Yup R14
Don't know ware to find parts so I thought it out there and
see what I could find out.
Someone nocked the top out of the piston and I'm notsure
if it's cast Iron or Steel.A file barely scratches it.
Old 08-01-2007, 12:19:38 AM
Steve, Look up Hit & Miss enterprises.
They have alot of parts for this engine.I put in an order yesterday. Parts for mine should be here in a couple weeks.
Old 08-01-2007, 12:56:59 AM
Redwing Redwing is offline
yep I done sometimes repair by weld then turning or milling. if piston is isn't available anywhere or too expensive to buy new.
Weld pac 155 cord and gas grub54891 Welding Shop 4 08-27-2007 06:04:38 PM
Can you weld the top of a piston? Steve Page Welding Shop 3 08-26-2007 10:13:10 AM
JB Weld DanR Antique Gas Engine Discussion 1 07-30-2007 03:10:03 PM
weld or epoxy kulkadave Welding Shop 6 04-30-2007 07:47:25 AM
JB Weld Mike Antique Engine Archives 18 03-08-2001 12:06:27 AM
