1949 international pickupI was wondering if anyone knows were to find a pistion for a 1949 international pickup truck.:shrug:this thread has 7 replies and has been viewed 2806 times
Egge Machine Works (Google) can supply pistons for just about anything.
You can also check oldihc.org ( or .com, or .net, I can never remember) for NOS parts sources. Good luck.
Besides Egge, PER has some sources besides. They seem to do a lot of Green Diamond engines (which I assume you have), and probably know of some other sources.
800-829-1276 http://portlandenginerebuilders.com/index2.html |
Sorry about the redundancy, sorry. Guess I was not paying attention, I guess.
If memory serves me, the green diamond did not come out until 1955 or so, as a replacement to the Silver Diamond series. The silver diamond early version was built from 1949 to 1952, and the later SD, 1952 to 55. The early SD series 220 and 240 CID had poured insert bearings, and the later ones had modern day shells. Both had problematic sodium filled exhaust valves.
The GD engines were totally modern type construction,Andrew
| Detroit in a Pickup. | Tommy Stojanov | Trucks, Trailers and Hauling for Shows | 45 | 11-18-2009 01:51 PM |
| 28 buick, pickup hot rod | Andy Williams | Antique Autos and Trucks | 4 | 09-26-2008 03:28 PM |
| 1949 chevy 1 1/2 ton parts | Jordan | Antique Autos and Trucks | 2 | 09-30-2007 05:35 AM |
| 1949 Case VAC/ Autolite distributor | smcowboy1974 | Magnetos, Ignition Coils and Spark Plugs | 0 | 11-09-2006 05:16 PM |
| Gas tank pickup tube | JCullom | Antique Gas Engine Discussion | 20 | 10-10-2005 08:59 PM |
