Champion Forge Blower value?I have a Champion Forge Blower with the Coal grill on a 3 legged stand. It blows up from the bottom...this thread has 10 replies and has been viewed 5579 times
I have a Champion Forge Blower with the Coal grill on a 3 legged stand. It blows up from the bottom in the center of the grill.. I have an interested buyer for this but i have no idea how much to ask for it. Does anyone know about what they are selling for? Thanks
I Get My Corn From A Jar
Hello,
A few questions about the forge... They're worth more if the bottom is crack-free and the metal has not eroded. Do all the parts fit together well? Does the blower blow and does it move easily? Is the blower stand intact? If all that's good, then you have a great forge that you should consider keeping and learning how to use. You won't believe this, but a new one from Centaur Forge costs upward of $700 without a blower, so don't give it away. I haven't priced one for a long time, so I don't know what to tell you it's worth because there are big ones and small ones, but it's worth more than you think. Get me details and I'll help more if I can. Don't give it away, repeat, don't give it away. Larry |
the forge blower seems to be in very good working order. with no cracks or breaks on the bottom shoot. or elsewhere. The cast part that sits inside the grill is very rough and did break in half. I might be able to have a coworker weld it back. but its pretty rough. the grill needs a new bottom but it looks like it can be replaced. it has small angle brackets around the bottom. The unit was inside a shed but the legs were in the dirt a few inches but they still seem solid just need to be cleaned off. There was/is a round rod that was through the side of the grill. Dont know what that was for if even if it goes there. Thanks for any Help
Oh its 18 inches in dia. and about 4-3/4" deep
the rod was likely connected to the clinker breaker a triangler chunk that sat directly in the center of the air hole
I just bought a Champion #400 hand cranked blower...just the blower only...and it is an oldie! It looks similar to yours but the mounting point is a little different (like it was made for a separate stand to sit beside the firepot) It's in great shape, turns easy and the gear train is smooth and quiet...no cracks...overall very nice and it should work well for the project I have in mind. I paid $140 for it and I suspect I "stole" it.
I have had similar units in the past, mostly stuff I recovered from fallout shelters (this was a popular use for the hand cranked blowers during the 50's and 60's) Currently, the new ones are VERY spendy...so much so that it is hard to believe it, let alone justify it. Hope that helps. rh |
Andrew a blower just like that went on e-bay yesterday, it sold for $90 with $75 shipping, but it had a big crack in it, he didnt advertise it like that he said it was good, but we sent him an e-mail with questions, It depends on the people, i know for a fact that i would not go over $100 for just a blower, but some might, i would say yours would be worth about $100-150, expecially if you sand blast it or just clean it up some, apperence sells!!!
Chris from Washington (the state)
Larry, Brand new forges on e-bay are $175 with electric blower, propane forges with 3 nozzles are aroung $300-400, If that person wants $700, i would tell him that he is crazy, you could buy a very nice propane one, a propane one with 8 nozzles on e-bay, 4 on each side ran off of propane is $800-900.
Go check out centaur forge for a look at what current production stuff costs....it is not quite a perfect comparison, however, since the one you have is an antique and although not in the nicest looking shape, would have some degree of collector value as well...especially to those interested in "the old west" and such.
http://www.centaurforge.com/ ![]() rh |
Andrew, Not a bad little forge you have there. Seems to be missing some parts but that really doesn't matter unless you are a collector but I don't think a collector would be interested in this one as it is a bit rough for display purposes. If you take ljcooper's advice (and mine) it will work fine for you to get started in blacksmithing.
These little settups were known as rivet forges or shoeing forges, used on construction sites to heat rivets, tool dressing/ tempering, etc. And by farmers to shoe their own horses. The griil top is missing. Yes, I did say "grill top" as this particular model was marketed as a combination forge/ BBQ grill! Also the ash gate seems to be missing from the bottom of the tuyere. The pan seems quite corroded but if you look you may see the words "clay before use". About an inch of clay is troweled in to the entire pan and is required or it will burn through. If you can get some housewife on ebay to buy it as a daisy planter for $300 I say go for it. Each year in September the Southern Ohio Forge Associatoin holds the biggest tailgaiting meet of blacksmithing equipment in the country called "Quad State" at Troy, Ohio. You will see dozens of these here and they go for $100 or less. My advice would be salvage the blower and scrap the rest, using the blower with a new firepot/ hearth table and get into blacksmithing yourself. You can find groups listed on the abana site www.abana.org. they are all over the country and are a great place to meet folks and learn the craft. Good luck. |
It looks like your forge pan is sheet metal not cast iron you can cut a piece and weld it in and make a good forge. The blower is a Champion 400.In the condition that the set-up is in I would sell (if it were mine) for $125 as the only thing thats good is the blower.When I tailgate at the blacksmiths conferences thats what I ask for a stand alone 400 blower.If you fix the pan and grate about $150-$185
forge and blower the top cone and shacker is missing $150. to $175. is fair.
| Coal for a blacksmith forge? | Chris J | Blacksmithing and Metallurgy | 17 | 04-14-2009 09:01 PM |
| RPM for #5 forge blower & creative use ideas | JKKD | Antique Gas Engine Discussion | 2 | 09-18-2007 03:45 PM |
| Buffalo Forge 8 x 8 | Jason | Stationary Steam & Traction Engines | 2 | 03-16-2005 08:56 AM |
| Champion Blower& Forge Co. | stan agacinski | Antique Engine Archives | 0 | 10-09-2002 05:12 PM |
| Fairbanks scientific forge | Bob Turner | Antique Engine Archives | 3 | 05-19-2001 08:12 AM |
