| Stationary Steam & Traction Engines Antique steam engines, traction engines, their boilers and the related things that make them run. |
Belting Up ... (how to?)does anyone have tips (step by step) for the young engineer, on how to belt up? i logged 15 hrs for...this thread has 52 replies and has been viewed 3542 times
#41
I'm no expert when it comes to belting up, but with the Prony brake I have had the opportunity to watch many others. I will relate one event that occured with a big old Huber tractor, not a traction engine. The tractor had a "paper pulley" made up of laminated paper. These are excellent when minimum slippage is what you want. After the we got the belt tight and the brake turning up to speed, the belt came off the pulley on the brake. In an heartbeat, my entire belt was wrapped around the pulley on the tractor. No one got hurt and no damage was done to the tractor. It took a whole crew of us to get the belt unwound from the pulley. My belt did not fare so well. I have since heard of one or two instances where this same thing has happened. I don' believe that either of them involved a traction engine.
I was reminded of this yesterday when I was holding the belt as we were belting up an 80 HP Case to a Baker fan. At one time, the top belt dropped down onto the bottom and came dangerously close to repeating this event. One thought about belting up to Baker fans or Prony brakes. The first time I ever used my Prony brake, I took many stakes, chains, and binders to be sure that I would be able anchor it securely. A gentleman stopped by to assist me, and when he saw what I was about to do, he suggested that I drive one stake in the ground directly in line with the belt pulley. I have never since used more than one stake to anchor my brake except for a small one that I drive thought the hole in the end of the tongue. With one stake directly in line with the belt, there is little tendency for the tension on the belt to pull the brake out of line. The second stake, off to one side, does very little, but is necessary. Sincerely, Bruce |
#42
Is this an Endless thread? or are we talking belts ?? LOL
John and I were just in last Sunday at the wdm letting one of the new students of the steam course get some more practice, lets say once he got belted up we didnt ask him to do it again lol. example was on the baker fan. 1-- Beltman, roll out the belt straight and square with the Fan, (not the fence its in) then flip the engine end of the belt over to the side to make room for the front and rear wheel of the engine on the pulley side ofcourse. 2-- If theres room allow the new student to drive straight in without undue weaving around obsticles (lumber pile, rock pile etc) Threasher belt ups via 2point turn etc should be the advanced part of belting up. 3-- Line up the inside front and rear edges of the pulley with the allready Straight Fan end of the belt and edge of fan pulley. 4-- As the engines front wheel nears the belt at the point that its bent out of the way, have the beltman pull it out Tight along side the engine, and stop the engine when the belt reaches the middle of the Rear axel (Nearly all engines apply) This should be just right to get it on the pulley with out excessive slack to take up and no fighting for the driver to get it over the pulley. 5-- Beltman will see that the belt is ontop or inside the front wheel , that nothing on top or the water tank or on the side of the boiler (grease cup etc) interfears with the belt. The steerman may use the flat of his hand on the back of the belt on the Pulley to steady it and back slowly and smoothly as possiblly into the belt (easy on a 2cyl). If your running a single its key that you dont stop before the belt is tight and then try to start again with the weight of the belt and machine on the engine its apt to spit the belt of with a sudden half turn to get rolling again. You may use the Friction clutch as most singles have one for this reason to tighten the belt other wise run ahead a bit and again back untill its tight. |
#43
I've never belted a steam engine, but seeing that first hand has always stuck with me and I just wanted to share that with the other people here trying to pickup tips on belting. This is NOT the engine that had the accident, but I would assume a similar configuration. I see JBoogie's 50hp has the belt guide that might help prevent this situation.
#44
yup, that engine is identical to mine, well except for mine is a rusty mess
looks nice, do you have a pic of the other side??? still can't decide if i want a shot gun stack or a "cabbage top"? some one brought up belt dressing, have you ever seen/used HONEY??? it looked like it worked pretty good. you could hear the belt peel off the pulley. |
#45
Man, I bet that'd scare the living daylights out of a lot of people!
I'm glad my Gaar's have the blowdown UNDER the boiler...my Case is a different story...but it's the side opposite the flywheel, at least!JBoogie, it's your engine, so do as you like...but if it was mine, I'd have to go for the cabbage stack! Just spent too much time as a kid playing with old "West" toy trains.... Mike |
#46
I P.M.ed Gary Y. and asked him to elabotate on "steering" or "guiding" the belt onto the center of the flywheel pulley. Here is is responce:
For my birthday on the 14th, Mike lined up the Case to his buzz saw and I put the belt on just as I tried to explain on the Stak. I stand about three feet in front of the engine's right (left on some [Peerless]engines?) front wheel. Holding your hands in a "clapping" manner with hands parallel and horizontal, I pick up the belt, which is already over the flywheel and when the engine backs up, 98 times out of a hundred, you "guide" it, keeping it in the center of the flywheel and before you know it, the belt is tight.
Andy Glines 16 HP Huber # 8213 19 HP Keck-Gonnerman # 1789 "There's just something about steam!" |
#47
Andy,
I knew you were a "computer geek"! Thanks for placing that on this thread. You just allow the belt to pull through your hands, holding it pretty much in place. 98% of the time it works, if you just watch the flywheel to see what you are doing.I actually came on here to warn, if your belt has a splice, make darn good and sure you have heavy leather gloves on, if it is a ratty splice. Thank goodness, our belts are both still endless, in spite of a slight "gear nick" I spoke of in an earlier post. Gary
#48
Thanks for the answer Gary. Forgive me for being dense because I am going to persue this a little more. Am I correct to assmue that you guide the belt with the belt that is between your "clapping" hands. I guess that you can push your hands away or pull them to you depending on which way the belt needs to go.
Again, thankyou for your unending patience with my silly questions.
#49
My post #48 was written while Gary was posting #47. My question is already answered.
Now it is time to confess why I am studying this subject so hard. I was at a show 2 weeks ago and I was having trouble getting the belt tight. I was lined up OK but I couldn't keep the belt on long enough to back up and get it tight. I was the only "steam guy" present at the time so the crew I was working with was not experienced helping get a steamer into the belt. They finally lost patience and hooked an infernal cumbustion machine to the Huber and pulled the belt tight I was pretty embarassed at the situation don't want to repeat it. . No body was holding the belt. I bet that if we did have someone holding the belt like has been described here things would have gone better.
#50
You've got it down pat! Finding that helper is the key. Gary
#51
[QUOTE=20 Reeves Highwheeler;235329]Andy,
I knew you were a "computer geek"! Thanks for placing that on this thread. QUOTE]Gary, even a blind squirrel finds a nut sometimes. I am to computers as most ladies are to automobiles. I push the button and it works and I have no idea as to how or why it works. I don't really care. This is why I like steam engines. The "how" and "why" are right out there where you can see and touch them.
#52
A lot of good points have been made. But forty years of experience has taught me a few finer pieces of information:
Someone mentioned sighting your flywheel or the pulley you are belting to (and you might want to do both), but younger folks might not know what this means. This is done by closing one eye and lining your open eye up with the near edge and the far edge of your flywheel and seeing where the two edges line up with the pulley on the other end. This helps you ensure your engine is in line with the implement. I often go down to the other side of the pulley and sight both sides to see if the engine is in line with the implement. The larger the pulley, you can sometimes see from the engine, but it often helps to check from the back. You might be straight with the engine, but off to one side or other and risk loosing the belt. Second, a good ground person is really important. Normally there will be slack in the belt such that as you back up the belt will slip on your flywheel. The job of the ground person is to have both top and bottom of the belt firmly in hand and guide the edges so that as they slip they don't slip off. You can do it without a ground person, but it will often take several tries as you back up further and further to put enough tension on the belt to make it run instead of slip (and of course, it gets harder and harder to get it up on the flywheel). This is where the metaphors get more and more colorful. And your ground person must be experienced enough to know when to let go!! And, finally, when I back into the belt I open the pet cocks. This allows me to ease the engine into the correct quarter to back up, and it will stay there. If the pet cocks are closed, the engine still has steam in the cylinder and will bounce back too quickly. The belt flops around, and your ground person has difficulty hanging on. Tom |
#53
A lot of practice, a little skill and much luck seem to work. I've noticed when most things go wrong is when someone wants to show off their skill, is when things don't quite work as anticipated. Keep your head and think it through and it generally works well.
As was originally stated, the "armchair experts" at belting, standing talking in your ear as you are belting up, at shows, are a more modern problem.
| Belting up for fun | Dustin D Ehli | Antique Gas Engine Discussion | 11 | 04-04-2007 08:24 AM |
| Belting up | Frank Y | Antique Engine Archives | 2 | 01-12-2003 09:25 PM |
| drive belting | Mike s | Antique Engine Archives | 8 | 08-28-2002 11:17 PM |
| Belting for IHC Vert A/C Eng | Fred S | Antique Engine Archives | 4 | 01-15-2002 11:42 PM |
| rubber belting | Roland | Antique Engine Archives | 1 | 07-16-2001 09:53 AM |
