| Antique Gas Engine Discussion Meet collectors of hit and miss engines, ask questions about collecting, restoring and showing antique flywheel engines. |
Fairbanks Morse MagnetoI have a quick ? that I'm sure is simple to someone who knows the answer. I just purchased a...this thread has 3 replies and has been viewed 2195 times
I have a quick ? that I'm sure is simple to someone who knows the answer. I just purchased a magneto and gear from Marks Magneto for a 1 1/2 Hp engine. The question is the gear does not have a mark on it, so how do you line it up to fire in time.
Is this an ignitor fired engine with the sumter rotary mag, or is it a spark plug engine with another make of mag, such as an FM R or J series?
rh |
If it is a high tension mag, rotate it until you feel the "Hard spot", this is where the mag fires or actually, just after the hard spot...mark the tooth that is in the twelve o'clock position with some red paint or something so you can keep it straight up...Now, with the mag off, rotate the flywheels until the piston is a few degrees before top dead center and hold it there. Now sit the mag on the bracket with the mark straight up and bolt 'er down. you should be within one tooth of where you mant to be. Plus you always have a quick reference to look at and see that it is in time...Anyway,that's the way I do it, and it has never failed me.
I don't pay any attention to timing marks, they may be wrong!
Check my 'Old Engines' page! https://www.facebook.com/pages/David...393732?sk=wall |
It's a spark plug engine magneto type FM.
| Fairbanks-Morse Magneto | Mike Schweikert | Antique Gas Engine Discussion | 1 | 08-11-2007 03:59 PM |
| Fairbanks Morse Z 3 hp Magneto Questions | Larry Evans | Antique Gas Engine Discussion | 8 | 05-15-2007 01:44 PM |
| Fairbanks-Morse Magneto | Jeff Miley | Antique Engine Archives | 0 | 01-26-2003 07:34 PM |
| FAIRBANKS MORSE MAGNETO | Stephen Porter | Antique Engine Archives | 1 | 12-07-1999 02:12 AM |
| Fairbanks-morse magneto | farmerjoe | Antique Engine Archives | 0 | 11-14-1999 10:58 AM |
