Mag for 1HP Titan or Famous
I would like to call on the wisdom of this forum for information as to what the correct mag would...
this thread has 6 replies and has been viewed 1421 times
Old 09-05-2007, 03:00 PM
Larry Anger Larry Anger is offline
Default Mag for 1HP Titan or Famous
I would like to call on the wisdom of this forum for information as to what the correct mag would be for a 1HP Titan or Famous engine. Also what would the correct gear be for that mag. Diameter and number of teeth would be most helpful. Thanks in advance! Larry.
Old 09-05-2007, 04:31 PM
LeRoy IHC LeRoy IHC is offline
Card Sponsor
Default Re: Mag for 1HP Titan or Famous
The magneto is an Accurate-Type R. The gear is the same size and number of teeth as the crankshaft gear.
LeRoy Baumgardner
Old 09-05-2007, 08:09 PM
Thanks Leroy, I appreciate the help. I have a 1HP Famous that I want to try resurrecting from the dead. It needs a lot of help. Larry.
Old 09-06-2007, 04:49 PM
Jordan's Avatar
Jordan Jordan is offline
correct me if iam wrong but don't they take the sumter no.12 as well. or am i thinking of a 1 1/2hp .
jordan
Old 02-20-2008, 05:51 PM
Images: 17
With a back geared mag set up, it's an "R" mag. But then again with the right bracket (G 8820) , it could use a Wizzard mag driven off the flywheel for 1911.
Did you make a new friend today, and a lot. Paul - "OLDIHC"
Old 02-20-2008, 08:17 PM
Don Oberholtzer's Avatar
Don Oberholtzer Don Oberholtzer is offline
Card Sponsor
The intermediate gear G7129 80 teeth. They also used a Sumpter JR mag.
Old 02-21-2008, 06:18 PM
Johnny T Johnny T is offline
I have a 1hp famous and it has a primer cup added to the top of the head and it has what I think is a lunk carb on it instead of ones like I've seen for the 1hp famous online. It was also converted to spark plug and I have no clue what they did to make that work since there is a box on the side of the base that has prongs out of it.
IHC 1 HP Famous or Titan? How to tell? CWC Antique Gas Engine Discussion 9 07-11-2012 09:09 PM
Ihc Famous or Titan? RBrigham Antique Gas Engine Discussion 2 10-25-2005 07:19 PM
IHC Famous/Titan Fred Van Hook Antique Gas Engine Discussion 4 07-29-2005 04:13 PM
4hp IHC Titan/Famous T/G Rex Pyles Antique Engine Archives 7 07-11-2003 05:28 PM
IHC Titan/Famous Bob Kern Antique Engine Archives 8 06-11-2002 06:07 PM
