Generators & Motors General Discussion Antique Generators, Light Plants and Old Electric Motors: Questions and answers about restoring and showing old power generation systems.
Cracked Exhaust Manifold
I discovered the manifold mounting ear at #4 cylinder cracked but still held in place with nut. It...
this thread has 1 replies and has been viewed 1316 times
Old 09-10-2007, 08:23 PM
hwh888 hwh888 is offline
Angry Cracked Exhaust Manifold
I discovered the manifold mounting ear at #4 cylinder cracked but still held in place with nut. It appears exhaust gases were passing by gasket at this location. Can these cast iron manifolds be welded? or am I into a new manifold at $100+. Any sources for a used one?
Thanks as always for the help!!
Old 09-10-2007, 08:57 PM
Default Re: Cracked Exhaust Manifold
A castiron piece can be more easily welded on a corner or edge than across the middle or interior of the part. Probably the most important thing is to bolt the part and the broken off ear down to something heavy and flat after V'ing out the crack. Then weld with a cast repair rod for only short distances at a time and quickly peen the weld to relieve as much of the stresses as possible.
A standard recommendation to repair cast iron by welding is to heat the whole part to above 1200 degrees F before welding, make the weld above that temperature, and then allow the part to cool over many hours.
For an ear like you have, I doubt this will be necessary, but you may want to allow it to completely cool between welds if you don't get it done with the first bead to minimize cracking.
If the resulting flange isn't completely flat, you may be able to carefully file or more likely grind it flat or even take the manifold to a shop and have it surfaced across the whole face to make sure it seals well. The cast iron next to the weld can be very hard after the welding.
I have welded in missing parts of a Ford diesel exhaust manifold with a small mig welder using standard ER70S-6 solid wire. the repairs were the "female" ends of a multiple piece manifold so they were sort of on the end of the part and had some room for expansion and contraction from the weld and normal heating and cooling cycles. Not pretty, sort of like a drunken mud dauber nest, but it keeps the exhaust in so far.
Exhaust manifold problems John W.L. Onan Generators 4 08-04-2007 09:51 PM
Welding Broken Exhaust Manifold Francis A. Antique Autos and Trucks 7 02-21-2007 06:19 AM
Wisconsin TH vs. TJD exhaust manifold Shootist357 Wisconsin Engines 1 01-08-2006 01:51 PM
Help again! Need exhaust manifold gasket dwelshans Generators & Motors General Discussion 5 06-19-2005 09:07 AM
wisconsin VF4 exhaust manifold chuck cleveland Generators & Motors General Discussion 0 09-21-2003 08:09 PM
