Hand Cranking Briggs Z
this thread has 3 replies and has been viewed 1857 times
Old 09-24-2007, 09:31:39 AM
Mike S's Avatar
Mike S Mike S is offline
Default Hand Cranking Briggs Z
What is the correct procedure for starting a Briggs "Z" with a hand crank?
I thought you were supposed to hold the compression release, crank it up to speed, and then let go of the compression release and keep cranking until it starts; but if I do this, it just wants to throw the crank off. I've had better luck letting off the compression release and the crank at the same time, and letting it coast to start itself.
Any thoughts on this?
Old 09-25-2007, 08:09:48 AM
Andy Williams Andy Williams is offline
Default Re: Hand Cranking Briggs Z
I have a B and i usually pull the compression release while cranking it 3 or 4 revolutions and let go of the crank and release at the same time. it usually starts right up.
Old 09-25-2007, 05:38:32 PM
Mike S's Avatar
Thats how I normally do it.
I think the problem is that I was cranking like crazy and when it kicked the crank off it was like when you're pulling on a rusted bolt and it suddenly lets go.......if you get what I'm saying . If you crank it a little slower the crank stays were it's supposed to.
I've also found that you can quarter turn it like a tractor, altough the best method is probably as you described.
Old 09-25-2007, 10:11:10 PM
BWegher BWegher is offline
I do it Andy's way. But I have never had a problem with the crank flying off on its own. Keep at arms length when cranking.
JD 720 Cranking engine will not start..Help Steamcar Antique Farm Tractors 9 04-01-2008 06:54:50 PM
Value of Briggs kick and hand start? JimS Small Air Cooled Gasoline Engines 4 06-28-2006 03:20:42 PM
Revisit: Value of Briggs kick and hand start? JimS Small Air Cooled Gasoline Engines 3 06-27-2006 06:29:41 AM
4.0 Bfa Cranking Problems pnora Onan Generators 6 04-17-2006 09:13:46 PM
cranking belted engines? Jebaroni Antique Gas Engine Discussion 11 12-21-2005 10:23:11 AM
