Help with IHC Famous cooling tank
Need advice on set up for the cooling tank on a 2 h.p. verrtical IHC Famous. Early model, no water...
this thread has 14 replies and has been viewed 1616 times
Old 09-24-2007, 11:30 PM
E.C. Mims E.C. Mims is offline
Question Help with IHC Famous cooling tank
Need advice on set up for the cooling tank on a 2 h.p. verrtical IHC Famous. Early model, no water pump. Screen cooled. Should bottom of water tank be raised to level of water input to the block or is a check valve used with the water tank set level with base of engine?
Old 09-25-2007, 12:23 AM
Bob Ronning's Avatar
Bob Ronning Bob Ronning is online now
Images: 4
Default Re: Help with IHC Famous
With no water pump you can not use screen cooling, you must use a tank. the top of the tank would have to be tall enough so the water can be as high as the top of the head. maybe someone here can give you the dimensions of the tank. Bob
Bob Ronning http://www.oldengine.org/members/sandwich/
Old 09-25-2007, 12:33 AM
Images: 1
Photo Re: Help with IHC Famous
The IHC Moguls which use screen cooling have no water pump and they work quite efficiently. The body of water is higher than the cylinder as you can see in these pictures.
Old 09-25-2007, 08:10 AM
Images: 4
Yes you could use screen coooling, but you would have to have the body of water verry high on a 2 h p verrtical IHC Famous. A tank was used on the early IHC engines with no water pump.
Old 09-25-2007, 03:11 PM
Nate S Nate S is offline
Default Re: Help with IHC Famous cooling tank
I have a 3hp vertical and a tank that is 56 inches tall and 12 inches across would work fine. Im not sure how much smaller a 2hp is than a 3hp, but it will give you something to work with. From what i can found oridgionaly they didn't use any screen cooling just a large tank to cycle the water.
Old 09-25-2007, 08:00 PM
Gene Fisher's Avatar
Gene Fisher Gene Fisher is offline
Images: 5
I have a 1907 8hp IHC Famous engine with a cooling tank and water pump which is all original and the pump is belt driven. A cooling tank is different than a screen cooler as no screen was used in the tank cooled and is earlier than with a screen. The pipe from the block came back to the tank and has a series of holes drilled in it to drop down on some trays with holes in them to drop back into the tank.
Old 09-25-2007, 08:31 PM
Brian Triebner's Avatar
Brian Triebner Brian Triebner is offline
Here's a picture of an early three-horse...
Old 09-25-2007, 08:40 PM
Thanks to everyone who responded. I will add a pump because I like the looks of a screen cooled engine and I have the tank and screen. It came with the engine. Any ideas on type of pump I can use and set up; belt, gear,etc.?
Old 09-25-2007, 11:20 PM
Card Sponsor
When A Mogul screen cooled runs it has to boil the water so it will go up the pipe to the cooling tank.it does it in spurts. The Moguls used kero. for fuel so they liked running hot so the screen tank isn't a problem.You could belt a pump off of the crank shaft with some kind of skinny pulley and a round leather belt or go find the newer side plate,pump bkt,pump,ecc strap,and add the ecc to your cam gear.Rob
Old 09-27-2007, 10:52 AM
Bob Johnson Bob Johnson is offline
Hi
I think that there is a picture with this that will show you the tank I made to cool my engine and one for another famous 2 hp. the water is cool enough after a days run that you can put your hand in it comfortablely. It is made of 8 " well casing and 1/8 " plate. It bolts to the 2 engine head studs.
If I can be of any further help just contact me
Bob
out west on the high desert
Old 09-27-2007, 09:16 PM
Bob:
Thanks for the reply. However, the picture is too small to see any detail and I have not been successful in getting it to enlarge. Any suggestions?
E.C. Mims
Old 09-27-2007, 10:03 PM
Don Oberholtzer's Avatar
Don Oberholtzer Don Oberholtzer is offline
Card Sponsor
Befor you start looking for waterpumps be sure your engine is set up to use one. Some early thermol syphan engines don't have the cam lobe that works the eccentric strap.
Old 10-02-2007, 11:11 PM
Lightbulb Re: Help with IHC Famous cooling tank
Changed my mind. I will restore it as original , with the cooling tank and no pump. Received some good advice on keeping it original.
So now, I have an extra screen cooling tank if anyone is interested.
Old 10-03-2007, 10:08 AM
Larry Anger Larry Anger is offline
E.C. - I have a 2HP vertical that never had a pump and I want to restore it this winter. I'd be interested in what you come up with as being original. If you could pass on this info. to me I'd be grateful. My email address is <langer5@sympatico.ca> Thanks, Larry.
Old 10-04-2007, 08:09 PM
Roger Steckhan Roger Steckhan is offline
Take a look at the May 2003, Gas Engine Magazine. It has a picture on the cover which showes a really big tank. Article on page 26.
IHC screen cooling tank Alex F Antique Gas Engine Discussion 2 06-08-2007 12:59 PM
famous cooling tank Jeremy Williams Antique Gas Engine Discussion 4 08-06-2006 05:13 AM
IHC Famous cooling tank Mike Smith Antique Gas Engine Discussion 4 11-14-2005 09:49 PM
FM -T cooling tank Dwight Vivas Antique Gas Engine Discussion 1 04-08-2005 07:19 PM
Cooling Tank D.J. Baisch Antique Engine Archives 1 07-22-2002 09:57 PM
