McCulloch chainsaw
i have a mcculloch super 250 chainsaw and i was wondering what model of engine did they use in ...
this thread has 3 replies and has been viewed 2623 times
Old 09-27-2007, 12:16 AM
dennis gresch dennis gresch is offline
Post McCulloch chainsaw
i have a mcculloch super 250 chainsaw and i was wondering what model of engine did they use in this chainsaw like mc93/mc100/mc101 ect
i have parts on ebay and i keep getting asked this questions
thanks for all the help
Old 10-07-2007, 11:33 AM
old saw guy old saw guy is offline
Wink Re: McCulloch chainsaw
look on the bottom of the saw. There should be model and Serial Number.
Old 10-07-2007, 12:19 PM
L. Brander L. Brander is offline
Default Re: McCulloch chainsaw
Look for any tags or numbers on the bottom of the saw. The series number may be of some help to you. See the attached links for series numbers and engine size. Hope this helps Lewis.
Super 250, 5.3 cu in engine with series #600100, prefix # 12, A12. Link: http://www.acresinternet.com/cscc.ns...1?OpenDocument
Super 250, 4.9 cu in engine with series #600100. Link: http://www.acresinternet.com/cscc.ns...3?OpenDocument
Old 10-26-2007, 09:42 PM
GADavis GADavis is offline
This saw used an engine cylinder that was comparable to the Mc49C kart engine. The crankshaft will not work as it is a straight shaft with a left hand thread for the clutch. The kart engine used a tapered end crankshaft like the 640 gear drive saw which also is quite like the 49C kart engine. Worked with McCulloch in the 50's,60's &70's.
MCCulloch problems john hatc. Small Air Cooled Gasoline Engines 3 11-15-2009 07:19 PM
1962 McCulloch BP-1 swampfox Garden Tractors / Mowers / Scooters 5 05-27-2007 11:48 AM
mcculloch yellow dennis gresch Chain Saw Collectors 1 04-29-2007 08:10 PM
Help this Mcculloch flywheel is not budging (and a ST-100 homelite)) Nork Small Air Cooled Gasoline Engines 14 01-18-2006 09:36 PM
15 hp. McCulloch Outboard Motor Marvin Bartlett Antique Engine Archives 0 11-07-1999 11:48 AM
