| Antique Gas Engine Discussion Meet collectors of hit and miss engines, ask questions about collecting, restoring and showing antique flywheel engines. |
John Deere 1 1/2 E cartAnyone with an oringinal cart if you could give me the dimensions of the handle on the JD 1 1/2 E...this thread has 2 replies and has been viewed 1181 times
Anyone with an oringinal cart if you could give me the dimensions of the handle on the JD 1 1/2 E cart. I want to make one and need the dimensions. Thanks.
I still have not received any mesurements on the handle. Would like to make one close to the original. Thanks
Hi Randy,
Enclosed are some photos of my 1 1/2 JD original cart.The handle is .320 Dia. So I think it is 5/16 under the paint.The handle loops around the axles just inside from the wheels.The handle sides are 29" from the axle center to the bend.The distance across the handle is 7 1/4".The center of the handle is bent out about 3/4" from straight.This is probably just mine and not what is when new. Also not sure if the handle should loop over from the top or bottom?When it was shipped to me about 25 years ago it was in pieces.I guess it would work either way.You may need to check other cart pictures. I hope this helps you. Regards, Jim McCracken |
| John Deere 6hp cart | Johan_Deere_E | Antique Gas Engine Discussion | 0 | 10-22-2007 02:01 PM |
| John Deere 3HP cart | Ryan Anderson | Antique Gas Engine Discussion | 1 | 01-02-2007 09:47 PM |
| John Deere 6 H.P. Cart ? | Andrew Albrecht | Antique Gas Engine Discussion | 0 | 05-03-2006 01:11 PM |
| john deere E cart | tim rostar | Antique Engine Archives | 4 | 03-28-2004 07:30 AM |
| John Deere Cart | Russ | Antique Engine Archives | 2 | 06-08-2001 11:46 AM |
