Wisconsin Engines
Milling Wisconsin Engine
I am restoring a Wisconsin AKN Engine, and have found out that the block (to which the head is...
this thread has 5 replies and has been viewed 1190 times
Old 10-20-2007, 06:37 AM
Jimmy's Avatar
Jimmy Jimmy is offline
Images: 52
Default Milling Wisconsin Engine
I am restoring a Wisconsin AKN Engine, and have found out that the block (to which the head is bolted) is not perfectly flat, and when you rev it, smoke comes out of it.
Do any chain stores/shops mill down old engines?
I live in Ohio, and I already tried KOI (they do all of my valve jobs) and they said they can't do it.
Any suggestions?
Old 10-20-2007, 07:22 AM
Elden DuRand's Avatar
Images: 6
Default Re: Milling Wisconsin Engine
Jimmy:
If you can find someone with a big enough vertical mill, it can be milled with a flycutter. You'll have to strip the engine down to bare block to do it, though.
In the past, I've used a really big file that will cover the whole deck of the engine. By carefully filing absolutely flat across the deck in a random manor, minor humps can be flattened.
That's how I flattened the de-valved deck of the Lenoiresque engine seen here:
http://www.oldengine.org/members/dur...ir/Lenoir.HTML
Take care - Elden
Old 10-20-2007, 07:27 AM
JKWidener's Avatar
JKWidener JKWidener is offline
Images: 26
Thats a cool little engine you got there Elden, you got any video of it running?
Never assume the obvious is true. -William Safire-
Old 10-20-2007, 10:10 AM
Ed Wright Ed Wright is offline
One time I took a four cyl continental block into a shop for a valve job and they belt-sanded the block and head . Can't say if i would recommend the practice. I didn't want to take any chances with it so did some more searching and found a shop that could shave the block in their mill. Just be carefull where you take it and ask questions.
Old 10-20-2007, 04:57 PM
Beanscoot Beanscoot is offline
Well I'm a general (not automotive) machinist and have milled a few heads and intake manifolds. The difficulty is in holding the part on the milling table if, as typical, it doesn't have convenient parallel machined surfaces opposite to those to be machined. It only needs to be disassembled enough to hold in the mill, if you don't mind chips getting in.
Automotive machine shops should be able to skim the surface as well, for probably less money as their equipment tends to be more easily adapted to odd shaped parts.
Eldon, that article about the Lenoir engine conversion looks very interesting and well done. I don't have time to read it now, but I look forward to later.
Old 10-20-2007, 07:05 PM
Images: 6
JK:
Not yet. I still want to do some more "engineering" on it to make it run better. When I do, I may borrow someone's camcorder (mine died) and make a short video.
Needless to say, it's a sorta funky sounding engine.
Take care - Elden
Milling machine john dodd Scale Model Engineering 7 08-21-2007 08:28 PM
milling machine john dodd Scale Model Engineering 9 06-11-2007 08:05 PM
Milling Machine Question holmesjsh Antique Engine Archives 9 12-13-2004 09:06 PM
Off Topic--Milling Machine Help Jim Tremble Antique Engine Archives 3 10-07-2003 07:53 PM
CNC milling John Herald Antique Engine Archives 3 09-08-2003 09:38 PM
