Trailer brake question
I am going to put brakes on my two axel trailer, but only on one axel , my question ...
this thread has 13 replies and has been viewed 1930 times
Old 10-24-2007, 06:27 PM
21avery 21avery is offline
Default Trailer brake question
I am going to put brakes on my two axel trailer, but only on one axel , my question is will it be better on the front axel or the back one ? thanks Scott
Old 10-24-2007, 06:35 PM
BRIAN GUEX BRIAN GUEX is offline
Default Re: trailer brake question
I Would Recomend The Rear Axle. My Trailer I Bought Has It On The Rear Axle. Most Of The Weight Is On The Rear Axle.
Old 10-24-2007, 07:09 PM
tb2040g tb2040g is offline
Hello ,Some states require the brakes to be placed on the front axle.This is because if the trailer becomes seperated from the truck the front will fall down picking up the rear axle. Most new trailers have a breakaway device to automatically apply the brakes after seperation.If you pull much weight,or do it with a small truck put brakes on both axles. Thanks
Old 10-24-2007, 07:23 PM
KeithW's Avatar
KeithW KeithW is offline
I would recommend both axles. I've got electric brakes on my big two axle trailer. Sometimes after driving over dirt roads rocks have knocked some of the wires loose, usually at the wheel. Being down to two out of four is bad enough. I'd hate to be down to zero out of two. On the Ajax trailer I have brakes on both axles and have run the wires in conduit.
keithw
Old 10-24-2007, 07:24 PM
BDMelon BDMelon is offline
Images: 11
Put brakes on both axles, your truck will thank you, & so will your automotive shop tech Trust ME, better to have too much brakes, than not enough ,, & wish you did both later, after the fact
Bdmelon
Old 10-24-2007, 09:35 PM
Mike Monnier's Avatar
Front axle for the reasons mentioned above. After my experience this season I would recommend both axles. My engine trailer weighs around 4k pounds loaded with brakes on only one axle. The brakes get the job done and I don't feel unsafe pulling it. Then I pulled my uncle's trailer with his oil field engine. It weighs around 8k pounds and has brakes on both axles. I had to turn my brake controller WAY down because the trailer was trying to jerk the truck to a stop. It was amazing how much better the braking was even with twice the payload out back! Go for it if you can swing adding brakes to both axles. I would also install a break away switch just for piece of mind.
Old 10-24-2007, 10:00 PM
Lcjudge Lcjudge is offline
Default Re: Trailer brake question
Many states now require brakes on both axles as well as the breakaway lockdown for the brakes should it separate from the tow vehicle. I don't think enforcement has been too stiff thus far but will be in the future. If you can put brakes on both axles, thats the way to go. Also, I have a trailer with surge hydraulic brakes on it. They are legal in only a handful of states and I understand there is a bit of a crackdown on them by enforcement officers. I don't pull mine now too far from home.
Tommy Turner
http://picasaweb.google.com/Lcjudge
Old 10-24-2007, 10:21 PM
I guess I was wrong, on only rear.
Old 10-25-2007, 03:47 AM
ListerDiesel's Avatar
I don't think we are allowed to have one braked and one unbraked axle on twin-axle trailers here in the UK, and as you are only allowed up to 3/4 ton gross weight on unbraked trailers, you need to have twin axle for anything decent.
We are just replacing our own unit, the new one will be very similar, twin axle, overrun (surge) cable brakes, 2.6tonnes gross, carrying capacxity 2 tonnes net. (1 tonne = 1000kg or 2200 lbs)
Once you get over 3.5 tonnes trailer gross weight you need to have powered brakes, usually air operated, we don't have electric brakes at all here.
Peter
Old 10-25-2007, 10:03 AM
both! from what i remember, assumeing your axles have the mounting flange, it's about 200 an axle to add all new brakes
adjust the brakes as tight as you can without dragging. the correct way is to tighten the brake up till it's snug, then back it off one notch at a time till the brake has no drag. if you get a situation where a couple of notches frees it up, but it takes 4 and 5 more to get rid of a tight spot in rotation, you need the drums turned. the tighter you can get it, the smoother the action and feathering of the brakes can be! keep them tight, trailer brakes have no automatic adjustment, easy to forget in modern times when you can ignore car and truck brakes till they grind.
the new controllers work great, stay away from the old style that needs to tap into the brake line to read pressure.
make the electrics robust! my trailers have a power and ground path that's constant, the ground wire goes all the way back to the plug and to the truck. grounding through the ball, and grounding the brakes to the frame (the connection is all too often on the bottom of the trailer and gets wet and dirty) will leave you with no brakes.
electric trailer brakes are, IMHO, a pain in the rear to keep adjusted and maintained, right untill you're finding yourself able to stop when the idiots in front of you are all stopping in the middle of the freeway.
Rob
Old 03-10-2008, 08:59 PM
Walt Roys Walt Roys is offline
It is best to have brakes on both axils without a doubt. If you are locked in to only haveing it on one , put it on the front. When you apply the brake hard, the front of the trailer will want to drop. If the brake is on the front. this action will tend to put more weight on the front axil where the brake is, thus giveing better contact with the road and therefore better brakeing without slideing the wheel.
Walt
Old 03-11-2008, 09:47 AM
Mike Cannon Mike Cannon is offline
When you come to Pennsylvania they will be looking for brakes on both axles and the breakaway switch system. I agree that the more braking surfaces we have to call upon, the better we all will be in these speedy times. Regards
Old 03-11-2008, 11:41 AM
KeithW's Avatar
I've got break away batteries on both of my trailers. I got tired of trying to remember to charge the batteries every once and a while. I picked up a couple little 2 watt solar panels and installed them on the trailers to keep them topped off.
keithw
Old 03-18-2008, 06:49 PM
LeRoy IHC LeRoy IHC is offline
In Pa. don't even think about brakes on just one axle. You must have brakes on all axles with a break away switch. If they pull you over and you don't have everything operational, they will deadline the trailer right on the spot. You can't pull it down the road to a garage or anything it stays parked right where you are until it's fixed. If you can't fix it at the location you have been pulled over you must call a wrecker to come get it. I went through it up on the turnpike. Got a $100 fine and the cop gave me a choice I had 15 minutes to to see if I could find the problem why the break away switch wasn't working or he'd order it to be towed. I found the broken wire spliced it he inspected the brakes to make sure they all worked and left me go. So I only had to pay the fine, if I couldn't have fixed it I would have, had to pay a wrecker. End of Story. I have been told that Pa. will no longer allow home made trailers to be titled because of legal libility. All trailers now must be factory built, if you have one that was built years ago and has a title you're OK as long as it passes the yearly state inspection.
Prony Brake Gary K Stationary Steam & Traction Engines 16 01-25-2006 03:37 AM
Trailer question Forrest A Trucks, Trailers and Hauling for Shows 1 10-25-2005 02:39 PM
Prony Brake ihorse Antique Engine Archives 11 11-09-2004 03:09 AM
trailer question David Greenwalt Antique Engine Archives 4 11-01-2003 10:15 PM
To trailer or not to Trailer? That is the question Adam Cottrill Trucks, Trailers and Hauling for Shows 5 08-03-2003 06:23 PM
