Welding Shop
Lincoln SA-200
this thread has 6 replies and has been viewed 10224 times
Old 11-08-2007, 07:57:33 PM
JackCroisant JackCroisant is offline
Default Lincoln SA-200
newbie to your board, This is the greatest forum I have ever been on, this is just really cool!!!!!!!!!! does any one have some pics of a early lincoln sa200
welder, a 1947 short hood is what I have and need to see how the air intake was ran and how the vacum idler was attached any help would be great thanks
jack
Old 11-08-2007, 08:04:53 PM
John Tozzi John Tozzi is offline
Default Re: lincoln sa-200
Go to Lincoln's website it is all there.
Old 11-08-2007, 08:57:27 PM
Do you mean in the operators manual because I've looked there and have one, but the air cleaner it shows is right on the carb and this one is on the other side of the machine thanks..jack
Old 11-09-2007, 01:17:05 AM
thanks I found a another manual with just that in it thanks jack
Old 02-12-2009, 03:00:07 AM
Round Beam Welder Round Beam Welder is offline
Default Re: Lincoln SA-200
hello I am currently run a 52 lincoln "short hood" and I took all the vac equip. off and I may still have the bellowes and my have factory vac. line if interstd con tac me here.
Old 03-27-2010, 09:34:53 AM
HoboHilton HoboHilton is offline
I have a couple of Short Hood SA 200's I'm working on. I too would like to get some orginal photos to check a few things by. Did you get any photos? Thanks
Old 04-02-2010, 01:04:17 AM
Dempster Dempster is offline
If you have a code number on your welder tag or it is also stamped on the generator barrel in front of where the starter is on engine. Enter that at Lincoln and will give you correct manuals for it. IM-114-C covers the short hood but lacking on any pics. IM-117-B covers the bellows type idlers. IM-127 also covers short hoods and shows some pics on linkages and more service info. IM-179-G covers gasoline engine adjustment for carburetor, timing, governor & vacuum idler. IM-179-G.1 covers vacuum R57 idlers. IM-277-A covers the electronic idler adjustments.
http://www.mylincolnelectric.com/Cat...ualsearch.aspx
http://content.lincolnelectric.com/p...m/obsomenu.pdf
Need help with Lincoln DC-225/3-AS Uncle Willie Welding Shop 1 04-26-2009 07:50:55 AM
Lincoln SAE 300 RandyCldwll Welding Shop 1 12-07-2005 02:08:41 AM
Old Lincoln Ben Bennett Generators & Motors General Discussion 0 09-28-2005 08:09:39 PM
lincoln help Todd Alexander Generators & Motors General Discussion 1 04-12-2004 10:51:22 PM
Lincoln Elk Mike Inglis Antique Engine Archives 1 09-10-2002 04:48:53 PM
