Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Blacksmithing and Metallurgy
Fixing old beat up anvils
I heard of a way to fix a bear up anvil (chunks missing) You can use brazing rod, and pre-heat...
this thread has 13 replies and has been viewed 3185 times
Old 12-13-2007, 12:09 AM
Chris J's Avatar
Chris J Chris J is offline
Images: 63
Default Fixing old beat up anvils
You can use brazing rod, and pre-heat the anvil first, then you can braze in the chunks missing, i have learned that the hardness of the steel will mix with the brazed part so it will still be hard, i have not done it, i know a guy that does it to all of his and they look very very nice afterward, and they still ring! can anyone here elaborate on this method? i am going to look into it some more, it has been a while since i talked to him, so maybe one of you guys out there has done this before?
Chris from Washington (the state)
Old 12-13-2007, 01:33 AM
Default Re: fixing old beat up anvils
You could also use J.B. Weld.
Kevin
Old 12-13-2007, 03:07 AM
Tanner Remillard's Avatar
Images: 10
When I was still in tech school a guy brought one in and we machined off about .300 to get it flat again. Guess it worked for what he wanted. I would think JB weld would crack and break off but I dont use the stuff, so I dont know.
Old 12-13-2007, 04:27 AM
Meco3hp Meco3hp is offline
Images: 19
Chris,
If you preheat a anvil to the temperature you'd need to braze it, you'll loose all the temper and then need to re-temper it! I can guarantee you it won't "ring" very good if you don't re-temper it. Also brazing won't hold up to any use on a anvil, as it's too soft. The hardness of the steel won't mix with the braze, it doesn't work that way! Also when you re-temper it, by the time you get the core of the anvil hot enough to re-temper it through, the braze will have melted away, unless you have lots of time to slowly bring it up to temperature. Also if somebody in the future did decide to "fix" that anvil right, they'd cuss you for an eternity for brazing it! I wouldn't even do it for "looks", as that'd make a lot of work for somebody in the future to fix it right. Leave it as is, or ask a blacksmith to fix it. Please refer to these links.
http://www.iforgeiron.com/forum/f7/a...uestions-2926/
http://www.iforgeiron.com/forum/f7/refacing-anvil-2821/
http://www.iforgeiron.com/forum/f7/can-anvil-saved-999/
Thanks!
Richard
Old 12-13-2007, 12:02 PM
Default Re: Fixing old beat up anvils
No really,
Paul Harvey recommends it for everything. He doesn't even use his welder anymore. Haven't you guys heard the ads on the radio?
Kevin
Old 12-13-2007, 01:12 PM
MCanady's Avatar
MCanady MCanady is offline
Hey Kevin I have an anvil at home that the heel is broken off of it. I never knew how I was going to repair it. Now where did I last see that heel? Merton
Old 12-16-2007, 12:26 PM
Jeff W B's Avatar
Jeff W B Jeff W B is offline
The best anvils are made of wrought iron with a tool steel plate forge welded on top. This plate is the only part of the anvil that is tempered. The best way to fix a chip plate on an anvil Is with fadtought960 welding wire. It will not chip or crank out. I have fixed several anvils this way. to fix the wrought part of an anvil use 7018 or the equivalent in wire. If the heal of the anvil is broke off where you need to weld the base and the plate, V the plate out to get to the base start with 7018 till you get to the plate then finish with the 960.
Jeff
Old 02-23-2008, 08:40 AM
JHFoster JHFoster is offline
I have read the above post and still do not have a clear understanding. I have a friend who wants to "restore" an anvil that belonged to his great grandfather. The farm hands beat plow points cold and buggered up the top of the anvil. How and who can repair this piece of family history? Thanks Jeff
"In the land of the blind, the one eyed man is King" M. Savage
Old 02-23-2008, 08:53 AM
brucegodlesky brucegodlesky is offline
Go over to the I ForgeIron site and ask there.
I know that there is specific rod to use and it involves preheat and postheat. bruce/birdog
Old 02-23-2008, 11:40 AM
Gene O. Carpenter's Avatar
Gene O. Carpenter Gene O. Carpenter is offline
Images: 16
Bruce,
Visit the following site for answers to just about any questions concerning "Smithy Work"..It's a site that deals in Black Smithing equipment and methods of performing certain jobs same as addicts of rusty old cast iron from years gone by find help here on SMOKSTAK .....
There have been recent discussions about such anvil repairs thereon. Hope you can find what you seek there..
http://www.abana.org
Old 03-03-2008, 07:27 PM
Jeff W B's Avatar
JHFoster ship the anvil to me, I will fix it up and ship it back.
Old 03-05-2008, 09:25 AM
Jeff, what is your post office box #?
Old 01-28-2009, 09:12 PM
TerryJay TerryJay is offline
I'm a member of a blacksmiths group in Okla. The SaltforkCraftsmen when we have an anvil repair day or days this is the procedure we use. For anvils with wought iron bases grind and CLEAN all surfaces to be welded. Grind through all folds or fractured chips.Chamfer all holes or severe depressions.Preheat anvil to 400deg a weed burner works well use a tempil stick to check the temp(welding supply store) when it melts its ready.Be carefull not to overheat around the heel and hardy hole its a thinner cross section.If the damaged aera goes thru the tooling plate start with stoody 2110(or equal)3/16 rod,unlimited passes.DC reverse works best it will run on AC. Base material will give about 45 rockwell c,To finish up build up the area in no more than 3 passes with Stoody1105(or equal)1/8 rod DC reverse(or AC) expect 50 to 52 rockwell C this comes as close to original hardness of the tool steel plate.
Stoody 1105 is a good match for w-1tool steel tops of most anvils,and is designed to be impact resistant.
For a cast iron based anvil preheat to 450 deg. and use NI(nickle rod) as filler then go with the stoody 2110
hope that helps
Old 04-14-2009, 08:55 PM
Brett Thompson Brett Thompson is offline
none slainless hard surfassing rods just weld a little each day so it can cool and not loose the temper in the rest of the anvil..
Anybody know anything about a "Beat 'em All" Engine???? (early Waterloo) Chris Epping Antique Gas Engine Discussion 3 03-29-2007 11:05 PM
Need Help Fixing Briggs! Kevmaster2000 Small Air Cooled Gasoline Engines 3 08-26-2005 12:06 AM
WAY TO BEAT FUEL COST Pix Tom Schoolcraft Antique Engine Archives 0 05-26-2004 01:17 AM
Anvils Hal Davis Antique Engine Archives 13 06-08-2003 11:56 PM
