Wico mag bracket 9013k ID?
need help to i.d. this mag bracket. the mounting bolts are 2 7/16 in. center to center there is a...
this thread has 4 replies and has been viewed 884 times
Old 12-19-2007, 12:08 PM
johnz johnz is offline
Default Wico mag bracket 9013k ID?
need help to i.d. this mag bracket. the mounting bolts are 2 7/16 in. center to center there is a no. 9013k cast into it. thanks for any and all help. john
Old 12-19-2007, 06:32 PM
GRookus GRookus is offline
Default Re: Wico mag bracket 9013k ID?
i would have to say that it is a stover ct mag bracket garyyour right not ct but for kb and kg style stover
Old 12-19-2007, 07:15 PM
Tom Martin Tom Martin is offline
It's not for a Stover CT engine, they don't have holes for a sparkplug, just an L shaped casting with two horizontal and two vertical holes. It might be for a Stover of some sort with the K in the number.
Old 12-20-2007, 03:59 PM
Jordan's Avatar
Jordan Jordan is offline
its a type 2 drive so that puts it into the 1920's. its not a masssey harris type 2 because the plug hole is on the other side. hope this info helps some.
jordan
Old 12-21-2007, 02:48 AM
Path Path is offline
John,
I have that bracket on my Stover KA, to mount the Wico EK Magneto. The 9013K is the old Symbol number, new Symbol is 42K according to the Stover Repair manual.
See my web site http://phutcheson.net under Projects. I have a close up of that bracket, see the 4th picture down on the left side. It's a thumbnail, click on it to enlarge.
Pat H
Wico bracket Bob Brown Antique Gas Engine Discussion 0 01-06-2006 04:03 PM
associated mag bracket Steve Kreiner Antique Engine Archives 3 03-11-2004 08:14 PM
Mag. bracket Chuck in Wisconsin Antique Engine Archives 0 04-27-2002 08:42 PM
Bracket. Joe Morris Antique Engine Archives 2 03-23-2001 09:04 AM
Mag bracket A-40 Randy Antique Engine Archives 0 03-10-2001 01:33 PM
