Onan 6BJD With Magiciter
this thread has 9 replies and has been viewed 2568 times
Old 12-23-2007, 06:59:26 PM
Phil T
Default Onan 6BJD With Magiciter
Hi am new to post I've read several post on onan generators and have found some really good info, my question or problem is as I was pulling the rear cover off my gen set I broke one of the brushes, is this part still avalable? or have I screwed up, help in florida. Exciter # SX1N 1B from what I have read in the posts this unit has a Magciter stator control unit serial # 85C839166 and the model # 6DJB-3E2236/1H. Thanks
Old 12-30-2007, 06:45:56 AM
Phil T
Default Re: 6BJD With Magiciter
Found brushes same diamentions will have to solder lead to contact now I need to find rectifier 305-0239 checked the stator and fields and found good check reactor gates and voltage control and resistors in mag all good also need to find engine parts the little engine just needs cleaned and resealed does anyone know how to find parts for these old units Thanks Phil
Old 12-30-2007, 09:18:53 AM
Gunny Gunny is offline
You can still get those brushes from Onan. They are proud of them but they do have them, well they did 2 months ago when I needed a set for a customers machine.
Old 12-30-2007, 05:06:59 PM
Phil T
How about the rectifier diodes part # 305-0239 ? I called the locale onan dealer but there closed for the hollidays I'll try them Monday Thanks for the info.
Old 12-31-2007, 01:04:16 PM
pcbye pcbye is offline
Email Not Working
Here are some part numbers and recent prices for Onan / Cummins:
Part OEM OEM Alternate Alternate Part Part
Description Part No. Mfg Part No. Mfg Quantity Price
MAGNECITER
Magneciter - Complete 209-0010 Onan 305-0899 1 $1,058.75
Magneciter Brush Holder 212-1064 Onan 2 $21.56
Magneciter Brushes 214-0059 Onan 4 $11.33
Magneciter Diode - Field Flash 305-0239 Onan 358-0097 1 $29.59
Magneciter Diode - Voltage Control 305-0240 Onan 4 $2.42
Magneciter Diode (-) 305-0238 Onan 358-0096 3 $29.92
Magneciter Diode (+) 305-0239 Onan 358-0097 2 $29.59
Magneciter Rear Bearing 510-0047 Onan Nachi 6205NSE 1 $39.49
Magneciter Resistor - 150 Ohm 50w 304-0512 Onan 1 $7.92
Magneciter Resistor - 250 Ohm 25w 304-0510 Onan 1 $21.30
Magneciter Resistor - Tapped 304-0527 Onan 1 $24.97
Reactor - Gate 315-102 Onan 305-0899 2 $1,058.75
Reactor - Voltage Control 315-100 Onan 305-0899 1 $1,058.75
Rectifier Assembly 305-0388 Onan 305-0899 1 $1,058.75
Regards;
Peter
Old 01-06-2008, 07:46:55 AM
Phil T
Thanks for your help, I'll try my loacale onan dealer again called them monday but not heard back from them, onan sure is proud of there parts.
Old 04-28-2009, 06:05:43 PM
cowboyrx cowboyrx is offline
I have a 15kW MDJF with this magiciter inside, and it is poorly corroded after sitting for several years. It does have 4 carbon brushes on the rotor.
Can it be replaced with an electronic voltage regulator, like later AA spec models (part# 300-1540)? If so, it'd save me a lot of money and time.
Old 04-28-2009, 07:44:06 PM
http://www.smokstak.com/forum/showthread.php?t=45741
Old 04-30-2009, 09:02:53 PM
Default Re: MDJF With Magneciter
Where can I get these 2 parts?
Old 05-10-2009, 08:15:48 AM
Phil T
Before you purchase any parts for your genset you should test all the componets in the magiciter because if one of the coils is open or shorted you will be money ahead to purchase the new electronic regulator, I do not know how to get this part but I know there are there are serveral folks on this site who do.
