1930 Mack. 1924 Gotfredson and a 4x4 Walter
Hi this is the first time using this forum, but I have just got myself a 1930 type BL mack and was...
this thread has 10 replies and has been viewed 3067 times
Old 12-31-2007, 06:15 PM
Corey Robinson Corey Robinson is offline
Default 1930 Mack. 1924 Gotfredson and a 4x4 Walter
Hi this is the first time using this forum, but I have just got myself a 1930 type BL mack and was hopeing to get some info and parts for it! any help would be great Also have a 1924 Gotfredson that I need parts and info for. And lastly I have a 4x4 Walter truck... I have no idea what year it is but any info or where I can compair pictures of it would be gerat!
Corey
Old 12-31-2007, 06:50 PM
JeffK's Avatar
JeffK JeffK is offline
Images: 11
Default Re: 1930 Mack. 1924 Gotfredson and a 4x4 Walter
for a start type in a search Jerrys wide world of walters orwww.roodness.com
Idle hands are the devils workshop
Old 12-31-2007, 07:28 PM
Tom Sampson's Avatar
Tom Sampson Tom Sampson is offline
Images: 72
A good Mack website is www.bigmacktrucks.com
Tom
Tom Sampson
ohio
check out my engine videos at http://www.youtube.com/user/steamer123
Old 01-01-2008, 11:11 PM
John Davidson John Davidson is offline
Here is a Gotfredson item I have. It is a aluminum casting with a raised rib on the back side and no holes or ways to fasten it. It is 10 1/2" long and 2 7/8" wide. Where does it belong on the truck?
Old 01-02-2008, 11:56 AM
On your Gotfredson (sometimes listed as Godfredson) it appears their 1924 line included (at least) :
Model 20 1Ton
Model 31 11/2T
Model 50 21/1T
Model 80 31/2T, and
Model 100 5T
Other model numbers shown with the above are like "20B, 30C, B24, W64A, RW104A", but I don't have anything that definitely lists each years models.
I have no idea where to look for a tag or stamp; all seemed to've used an assortment of Buda engines, and Mroz's book says used typical "assembled truck" parts.
There was a Walter 4x4 military model that used a Herc DHXB engine; the only reason I noticed was that I got a DHXB/C parts book with something else I bought, and was looking to see what used it. BUT my stuff is weak on military models, so there may've been others.
Old 01-05-2008, 07:17 PM
Hello!
thanks to Jeffk, Mr.Sampson, Mr. Davidson and Mr.Tierney.I found that the Mack was 1 of 506 built, but no luck on the other two. Mr. Davidson I have no Idea what that emblem could be from.... maby on the Rad? and mr.Tierney I found that my truck is a 4 ton!
Thanks again for the help
Corey
Old 01-05-2008, 11:46 PM
Wellll, lessee here...Tonnage is a little difficult to pin down.
McCord Gaskets shows 4cyl Models 80,W64A and W84A on one line, 31/2-4T, with Buda YBU or YBUI...
They also show 6cyl Models 86, W86A and 106 on another line, 4-5T, with Buda GL6... (McCord seldom shows years)...
Jadson Valves shows a Model 80, 1923-25, 4T, with 4cyl Buda YTU...
Houpert pistons only goes to 23, but does show the 80 as 4T with the Buda YTU for 1922-23.
Other catalogs of the period don't show tonnage, and it's not unusual for these old parts catalogs to disagree, to say nothing of someone dropping/shoehorning in another engine!!
Old 01-07-2008, 07:18 PM
Mr. Tierney:
I bought two Buda engines a coupple months ago that had the Gotfredson tags on them, the little one is Model WTU
B/M- 3887
Ser # - 151044a
and the big one is model - EBUT
B/M - 2663R
Ser # - 193637A
I have the transmissions with them as well but they didnt have any mags or carbs on them, what kind do they take?
Corey
Old 01-08-2008, 12:31 AM
Sorry, Corey, can't answer your question--my stuff is a few internal parts catalogs and a few fan belt catalogs; I've got nothing on carbs or mags.
The bigger engine is probably EBUI; Buda had several with the "I" variant (EBU,EBUI,KBU,KBUI,YBU,YBUI etc) and I don't see any with a "T" at the end. Nor do I know what the "I" designates, and my stuff either doesn't mention the variant or lumps them in with other models.
If you're close to a city with a decent public library, check with their reference section; they often have copies of old specs books (they never let anything that valuable out; you have to go look at it) with that kind of info, BUT they probably came with a range of carbs and mags, depending on the installation or the proposed use of the vehicle.
You might consider reposting as a separate question, and if nothing turns up trying ATCA, ATHS and Classic Trucks forum on yesterdayspickups.com. With sympathy, Bud
Old 01-08-2008, 01:19 AM
Forgot half of what I meant to say:
The KBU and KBUI, while with three others in the McCord, just show one b/s, and one set of gaskets (head, ex port, pan, bell hsg,valve cover and cylinder base for all five models), so the "I" must not be a b/s variant..
The EBU/EBUI are lumped with two others, and two b/s's shown, with no way to tell which was which...BUT all four take the same gaskets, EXCEPT for an oil pan and bell housing change in 1926, the oil pan and bell housing gaskets being for "prior to 26" and another set for "26-28".
The WTU is lumped with one other (MU) and shows two b/s's, with the WTU probably 33/4x51/8, but there's no "WTUI" variant shown, and no 25/26 gasket change.
Old 01-08-2008, 09:44 AM
Rick McKay Rick McKay is offline
Corey,
How about a few pic's of your trucks??????
Rick
1959 Mack Truck Tom Sampson Antique Autos and Trucks 25 06-04-2010 09:21 AM
Case Fan Belt 1930 Looking for jeff mn Antique Tractor Talk 3 10-11-2008 05:26 PM
1930 -33 fairbanks morse 11/2 Z Roger Korff Antique Engine Archives 3 10-07-2003 10:05 PM
Trying to find Walter Sappington Garth McPhie Antique Engine Archives 0 07-13-2003 01:34 AM
