Army tank generator
:wave:any info on a starter gen for a old army tank, this unit was started to give the battery...
this thread has 9 replies and has been viewed 1374 times
Old 01-04-2008, 11:41 AM
Tom Kilgore Tom Kilgore is offline
Arrow Army tank generator
any info on a starter gen for a old army tank, this unit was started to give the battery extra help in starting and to run the electric system without the main engine. it was a 1 cyl. with the cyl . pointing down. i think the GIs called little joe or little moe. any one have one or info.
Old 01-04-2008, 01:03 PM
"TheToolman"'s Avatar
"TheToolman" "TheToolman" is offline
Images: 16
Exclamation Re: army tank gen.
we had a "LITTLE JOE" it was mounted to a JEEP trailer with a fuel tank from a duce & 1/2 . we used it to start things in the field & the fuel tank for our emmersion heaters for hot water to heat "C" rats. and fuel our space heaters in the winter
[DEER HUNTERS]-
Check out this site
www.thedeercamp.net
Old 01-04-2008, 04:06 PM
Images: 10
Default Re: army tank gen.
Tom;
Delco-Light made a small generator that was used in tanks and it was called "Little Joe". I got some printed information from a fellow in England that gave directions to convert the tanks from the Little Joe's to "Tiny Tims", which was merchandised by Montgomery and Ward and I think Sears also sold some of them.
The Little Joe's were made in 6 and 12 volt models. The Tiny Tim's were made in 6, 12, and 32 volt models.
None of the above has the cylinder pointing down. They were a typical 4 storke vertical "L" head design.
A picture of yours would be nice to view.
"DELCO DON" Southern Illinois
Old 01-04-2008, 04:55 PM
i am looking for one, i seen 1 about 50 years ago and the carb
was open and ran wide open. the crankshaft was in two parts
with a ball bearing on the connecting rod and one side of the crankshaft drove the gen and the other side the rest of the motor. I am recalling all of this from memory so it could be
wrong.
Old 01-04-2008, 07:34 PM
Exclamation Re: Army tank generator
With the inverted cylinder, it sounds like an Onan outfit.
Old 01-04-2008, 08:04 PM
John Newman, Jr.'s Avatar
John Newman, Jr. John Newman, Jr. is online now
Default Re: Army tank generator
With an inverted cylinder, it is more likely a 2-stroke Homelite, in my opinion. Those were pretty common military units.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 01-05-2008, 12:13 AM
vern0n's Avatar
vern0n vern0n is offline
I have a Homelite tank heater. The cylinder points down. I forget what the voltage is. I can submit a picture if you want. I'll just need to drive to the barn and take one.
Old 01-05-2008, 04:22 AM
ListerDiesel's Avatar
Continental did a little tank battery genny, and there was the Johnson Chore-Horse as well, plus a few others.
Peter
Old 01-05-2008, 10:09 AM
Arrow Re: Army tank generator
peter any pictures would be great tom
Old 01-05-2008, 10:12 AM
vernon; a picture would be great thanks for the offer tom
Army generator Tom Rowe Generators & Motors General Discussion 5 10-21-2009 09:38 AM
1943 army generator M5 KBach1021 Military MEP and Aircraft Gen-Sets 2 11-28-2008 06:03 AM
U.S.Army Generator PE-108E Leland Antique Gas Engine Discussion 2 10-18-2006 03:31 AM
army generator parts Russell Daves Generators & Motors General Discussion 1 08-15-2004 08:07 PM
1941 Army generator Calvin C. Generators & Motors General Discussion 0 09-08-2003 05:07 AM
