Ignition wire
Does anyone know if Packard 440 solid wire ignition cable is available with red casement sheathing,...
this thread has 5 replies and has been viewed 914 times
Old 01-19-2008, 11:50 AM
Question Ignition wire
Does anyone know if Packard 440 solid wire ignition cable is available with red casement sheathing, instead of the usual black? I am restoring a 1951 ALF 527 CI V 12 engine, and mice have chewed the red casement ignition wiring to bits! It must have tasted better than the black, as the black is nearly untouched!!!
Old 02-12-2008, 01:21 PM
Robert Haus Robert Haus is offline
Default Re: Ignition wire
I have bought wire from Bill Lopoulos...the stuff I have is the red with black tracers...maybe not exactly what you want but it looks good...he also has other colors available. He advertises on this board as do others who carry this sort of wire, so it should be easy to find something to your liking.
Old 02-15-2008, 04:03 AM
Thumbs up Re: Ignition wire
Thanks Robert, I will look him up.
Old 10-05-2009, 06:22 PM
mcgyver mcgyver is offline
Andrew, you might also try "the Brillman Co." they have a good selection of wire
Old 10-05-2009, 09:00 PM
Sky's Avatar
Sky Sky is offline
Images: 45
It was probably cherry flavored. Not to many like black liqorish.
20th Century Machine's http://www.youtube.com/user/VintageClassic1
Old 10-08-2009, 12:03 PM
Dempster Dempster is offline
I keep some 7mm red silicone metallic core wire for magnetos it's made by Taylor Wire. Taylor makes all colors of wire now. If you want the cloth braided wire plain or other colors check with Brillmans. There is a dealer locator on the Taylor site also.
http://www.taylorvertex.com/
The Following User Says Thank You to Dempster:
Need source for old-pattern ignition wire tirediron Antique Tractor Talk 3 03-08-2007 10:00 PM
New Copper Wire 6hpMarty Generators & Motors General Discussion 7 12-02-2005 12:44 AM
How much wire? DanR Antique Gas Engine Discussion 3 08-05-2005 10:46 AM
Ideal/Blufton ignition wire diagram needed. chase Antique Engine Archives 1 01-01-2003 12:45 AM
curled ignition wire...why? Dave Brink Antique Engine Archives 20 12-13-2001 09:41 AM
