Belting for IHC Vert A/C Eng
Does anyone know the proper diameter and length of leather belting to use for a 2 HP Vert A/C IHC...
this thread has 4 replies and has been viewed 523 times
Old 01-15-2002, 01:35 AM
Fred S
Default Belting for IHC Vert A/C Eng
Does anyone know the proper diameter and length of leather belting to use for a 2 HP Vert A/C IHC Engine? There are several dia's available. Also, how to connect the belt together. I'm new at this. Thank you very much. Fred in MI.
Old 01-15-2002, 12:59 PM
BEN BENNETT
Default Re: Belting for IHC Vert A/C Eng
I could'nt tell you what size belt you need but I do know that the equipment that you run usually had specs as to how long the belt should be. The length/weight of the belt has a lot to do with the "grip" on the pulleys. The belt tention usually don't help much because most equipment was not stationary and when you tighten the belt so goes the equipment(moves on you). There are two types of fasteners one is "clipper" which needs a special tool to close up, the other is alligator which fastens with a long pin. The alligator makes a lot of noise as it crosses the pulleys (would not recommend)...........ben
Old 01-15-2002, 05:33 PM
Ted Brookover Ted Brookover is offline
We used 3/8 round leather belting on ours, we got it at the Missouri Sewing Machine Co. in Kansas City.
Put the belt together with a single "Hog Ring" like is used in furniture upholstery.
As for length, cut the belt a 1/2 inch or so shorter than the measurement around the flywheel and the fan pulley.
Old 01-15-2002, 07:44 PM
Randy Peterson
Check HARRYs sponser ads Ol Ed (pack rat)has just what you are looking for with the fasten clips at Hit and Miss Enterprise.
Havin a blast preservin the past
Randy Peterson
I think I have his catologe memorized
Old 01-15-2002, 11:42 PM
Fred S
To Ben, Ted and Randy. Thank you very much for your information. I really appreciate it. Thank you Harry for the site. I cannot say enough about the good people in this hobby. Fred
Belting Up ... (how to?) JBoogie Stationary Steam & Traction Engines 52 08-16-2007 03:16 PM
Belting up for fun Dustin D Ehli Antique Gas Engine Discussion 11 04-04-2007 08:24 AM
Belting up Frank Y Antique Engine Archives 2 01-12-2003 09:25 PM
Belting Question Kevin Bandy Antique Engine Archives 4 01-15-2001 07:33 PM
Supplier for belting Ed Jablonski Antique Engine Archives 2 09-18-2000 04:50 PM
