Need help finding an Onan part number
i have a 6.0DJE and i need an injector pump, if any of you know what the part number is that would...
this thread has 2 replies and has been viewed 970 times
Old 01-25-2008, 02:57 PM
mechaniman mechaniman is offline
Default Need help finding an Onan part number
i have a 6.0DJE and i need an injector pump, if any of you know what the part number is that would be awesome.also if you know where to find one let me know, i also need the lever that sits on the injector pump shaft which connects to the govener. thanks you guys
Old 01-25-2008, 04:05 PM
John A John A is offline
Default Re: need help finding part number
Parts should be available from any Cummins dealer.
Going to need model and serial numbers.
John
Old 01-25-2008, 04:13 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: need help finding part number
From an OLD Parts Manual... Injection Pump is a: 147C185 But you will also need to
tell the Parts Guy, the Button Numbers from the Tag on your Pump. One for each
Injector Line.
Bruce in alaska
cant find part number petey2000 Magnetos, Ignition Coils and Spark Plugs 3 01-08-2007 02:16 AM
Part number to oil seals Sky Small Air Cooled Gasoline Engines 3 11-19-2005 06:50 PM
piston part number question Sky Antique Gas Engine Discussion 4 10-26-2005 01:51 PM
CAn U HELP ME CROSS A CUMMINS/ONAN Injector Part Number to Bosch's Part Number? David R. Onan Generators 2 09-29-2005 06:43 AM
Looking for a Bosch Injector Part Number from Onan Part Number David R. Antique Marine Engines and Outboard Motors 0 09-28-2005 11:09 PM
