MEP017A dieselpower
Well after all the help from jim on the wiring , i started putting the unit together i completed...
this thread has 6 replies and has been viewed 1051 times
Old 01-25-2008, 09:46 PM
panzerwillie panzerwillie is offline
Smile MEP017A dieselpower
Well after all the help from jim on the wiring , i started putting the unit together i completed the fuel system and started putting the controlbox i will keep most of the military gauges in exeption for the load gauge which i replace with a military AMP gauge , most of the military wiring will be gone so it should be a clean install as i have wire it for single phase , i tok some pictures and looking foward to complete it in the next few weeks so i can load tested.
ID:	28610 Click image for larger version
ID:	28611 Click image for larger version
ID:	28612 Click image for larger version
Old 01-26-2008, 12:32 AM
Merritt Merritt is offline
Default Re: MEP017A dieselpower
looks cool.. what size is the generator?
i also live in miami, what part of town are you in??
Old 01-26-2008, 12:36 AM
Smile Re: MEP017A dieselpower
Is a MEP-017A which is a military 5KW that came with a 2 cylender gas engine , i live outside kendall
Old 04-17-2008, 01:18 PM
jas67 jas67 is offline
That looks like a Yanmar L-series air-cooled diesel on that.
The MEP017A was originally a gas-powered unit. Did the military retrofit those with Diesel engines?
-- Jay
Old 04-17-2008, 11:24 PM
Talking Re: MEP017A dieselpower
It isthe Yanmar engine form a military 4kw and no the military didnot rpower the herculies engine with the yanmar i did
thanks
Old 04-18-2008, 08:34 PM
I assume that these other's are you:
http://ebay.com/Military-Generator_W0QQitemZ180228890985
So, did you make a 2nd one?
Do you have any others?
Old 04-19-2008, 07:24 AM
If i get another Yanmar engine i will. also the deuzt engine works as well
thanks
Mep017a John T Military MEP and Aircraft Gen-Sets 3 06-15-2005 09:57 AM
MEP017A neutral/ground John T Military MEP and Aircraft Gen-Sets 1 10-02-2004 10:07 PM
