Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Engines and Power Units
Waukesha 4BU3
I have an engine that I picked up at a swap meet last fall. I have a Pettibone fork lift with a ICK...
this thread has 3 replies and has been viewed 277 times
Old 03-08-2008, 10:49 AM
blacktinlizzie blacktinlizzie is offline
Default Waukesha 4BU3
I have an engine that I picked up at a swap meet last fall. I have a Pettibone fork lift with a ICK engine and was hoping this engine would supply parts. The swap engine is a 4 cyl flat head model 4BU3 I was told that this engine powered an ac unit on a 1950's GMC coach. I can find no listing for this engine in my Waukesha General instruction book any info would be helpfull thank you Bill
Old 03-08-2008, 11:41 AM
Default Re: Waukesha 4BU3
Do you have any casting numbers?
Old 03-08-2008, 11:50 AM
I did not get casting numbers but tag reads 4BU 4BU3 1695 540 If it will help I will dig the engine out and look for more numbers Bill
Old 03-08-2008, 01:17 PM
Well if I had gone looking for more numbers sooner I could have answered my own question. Just to add some info the casting numbers are as follows
Head Alloy 503 A 121202
Block CHG 27522 casting date 2/5/40
ext mani faces to the front of engine
Dist Delco remy 1110414-ob1
Sissan auto choke
Thermo housing gmc part 211928 with a Kysor temp alarm built in
Starter Delco Remy 1108557 OK17
And on a second Waukesha id tag on block under 1/2 inch of grease ICK29 459685 governed to 1800 loaded
the first tag was mounted to bell housing Thank you Bill
Waukesha 1ck svenosu Multi-Cylinder Stationary Engines and Power Units 2 11-30-2007 07:58 PM
Waukesha mikemyer Antique Gas Engine Discussion 0 05-06-2007 02:20 AM
Waukesha 180-GKB JComan Antique Gas Engine Discussion 6 11-28-2005 11:34 PM
Waukesha Gen set Mac Leod Generators & Motors General Discussion 0 11-13-2004 08:32 PM
waukesha 2 cyl. Ed Antique Engine Archives 3 12-05-2000 08:17 PM
