Hatz Diesel Settings
this thread has 6 replies and has been viewed 8399 times
Old 03-23-2008, 05:10:31 PM
windrush windrush is offline
Default Hatz Diesel Settings
Seeking assistance. I am replacing the cylinder head gasket on a Hatz diesel, Type ES75 247E
Model 161588185652
and was wondering if someone could furnish me with the Head Tightening Torque and the Inlet and Exhaust Valve clearances. I have a head gasket on order and am hoping to start reassembly later this week. The engine is on a vibrating roller and besides the gasket blowing it appears to have some fuel trouble as it will run for a minute ot two and then peter out, I found the filter had come adrift in the tank so am guessing that it has sucked some dirty fuel! No doubt I will sort it in the end.
Regards
Pete.
Old 03-24-2008, 04:59:42 PM
Jon V8 Jon V8 is offline
Default Re: Hatz Diesel Settings
Not a problem,I have a full set of Hatz manuals,parts books at work - I'll look them up at lunchtime tomorrow,cheers Jon.
Old 03-24-2008, 05:14:33 PM
Thanks Jon, that would be great! I have emailed the Hatz factory for information but I think that a reply is unlikely!
Old 03-25-2008, 09:49:02 AM
Hi,according to my book the head torque is 50 Nm and the valve clearances are both 0.1mm cold.Hope this is OK - shout if you need more info,cheers Jon.
Old 03-25-2008, 03:23:40 PM
Thanks for the info Jon, much appreciated.
Pete.
Old 04-01-2008, 01:28:35 PM
edward moller edward moller is offline
WINDRUSH
in order to properly replce a head gasket on a hatz engine you need to determine the bumping clearance between the top of the piston & the bottom of the cyl head. They make different thickness head gaskets, put two small pieces of soft solder on top of the piston dirrectly over the wrist pin. Assemble the cyl head,with a gasket,torque head. Rotate the engine till you feel the solder flaten between the piston & head. Now you know what the clearance is, now you can do t
the math to determine what thickness gaket you will need.
If I remember right the bumping clearance should be about .020. If it is to tight damage will ocurre, to loose it will be hard to start.
The Following User Says Thank You to edward moller For This Post:
Old 08-19-2010, 07:40:48 AM
naclk9 naclk9 is offline
Hey All
Thanks, this thread helped me out quite a bit!
I have a hatz e89fg that's down on power and has a leaky cylinder head, and would have just went blindly ahead without measuring. Do i understand correctly that you can't just measure the existing gasket?
Also Does anyone know what that knob under the hole in the valve cover is? It seems to act on a shaft that is in front of the injector spray. I'm wondering if it has anything to do with tuning.
50 nm Is about 38 foot pounds right?
All the best
Pete M.
Hatz E 571 Diesel Engine Gilli43 Vintage Diesel and Oil Engines 2 02-16-2011 10:06:48 AM
What display screen settings are you using? Harry Antique Gas Engine Discussion 25 11-04-2007 09:26:21 PM
Valve Settings Charlie Gale Steam Stationary Engines, Traction Engines, Steam Boats 0 08-03-2007 12:46:33 PM
Suggestions on torque settings? gary johnson Kohler Generators 4 10-26-2006 09:27:16 AM
Webster K Mag and Igniter Settings Jim Tremble Antique Engine Archives 5 01-04-2002 07:52:20 AM
